Results 1 to 8 of 8
Thread: 2005 TOYOTA CAMRY
    JumboJet's Avatar
    May 2004
    Royal Palace
    28
    9,339
    Default 2005 TOYOTA CAMRY
    2005 TOYOTA CAMRY -459499
    2005 TOYOTA CAMRY -459500
    2005 TOYOTA CAMRY -459501
    2005 TOYOTA CAMRY -459502
    2005 TOYOTA CAMRY -459503
    Standard/LE SE XLE
    Engine 2.4-liter DOHC
    16-valve VVT-i
    4-cylinder
    160 hp [2] @
    5,700 rpm
    163 lb.-ft. [2] @
    4,000 rpm
    2.4-liter DOHC
    16-valve VVT-i
    4-cylinder
    160 hp [2] @
    5,700 rpm
    163 lb.-ft. [2] @
    4,000 rpm
    2.4-liter DOHC
    16-valve VVT-i
    4-cylinder
    160 hp [2] @
    5,700 rpm
    163 lb.-ft. [2] @
    4,000 rpm
    Ignition Electronic, with Toyota Direct Ignition (TDI)
    Transmission
    5-speed manual overdrive Standard Standard NA
    5-speed electronically controlled automatic overdrive with intelligence (ECT-i) Available Available Standard
    Drivetrain Front engine, front-wheel drive
    Body construction Unitized body with front and rear vibration-dampening sub-frames
    Suspension MacPherson strut front suspension with gas-filled shock absorbers and stabilizer bar; dual-link independent MacPherson strut rear suspension with gas-filled shock absorbers and stabilizer bar (SE models add sport-tuned shock absorbers, springs and stabilizer bars; and strut tower brace)
    Steering Variable-assist power rack-and-pinion
    Turning circle diameter, curb to curb (ft.) 34.8 36.7 36.7
    Brakes Power-assisted ventilated front/solid rear disc (power-assisted ventilated front disc/rear drum on LE 4-cylinder)
    4-channel 3-sensor Anti-lock Brake System (ABS) with Electronic Brake-force Distribution (EBD) Standard Standard Standard
    Vehicle Stability Control (VSC) [3] plus Traction Control (TRAC) and Brake Assist [4] NA on Standard
    Available on LE Available Available
    Standard/LE SE XLE
    Exterior Dimensions (in.)
    Overall height, unloaded 58.7 58.7 58.7
    Overall width 70.7 70.7 70.7
    Overall length 189.2 189.2 189.2
    Wheelbase 107.1 107.1 107.1
    Ground clearance 5.5 5.9 5.9
    Track (front/rear) 60.8/60.4 60.8/60.4 60.8/60.4
    Coefficient of drag (Cd) .28 .28 .28
    Interior Dimensions front/rear (in.)
    Head room 39.2/38.4 39.2/38.4 39.2/38.4
    Shoulder room 57.5/56.7 57.5/56.7 57.5/56.7
    Hip room 54.4/54.1 54.4/54.1 54.4/54.1
    Leg room 41.6/37.8 41.6/37.8 41.6/37.8
    Seating capacity 5 5 5
    It's been a long journey
    kewlsolara's Avatar
    Sep 2003
    Melbourne
    39
    822
    2005 is simply the 2002 camry with face lift and few extras
    http://www.extnix.com.au
    JumboJet's Avatar
    May 2004
    Royal Palace
    28
    9,339
    ya, same same but change in back lights
    JumboJet's Avatar
    May 2004
    Royal Palace
    28
    9,339
    but here new shape camry is 2004 model
    JumboJet's Avatar
    May 2004
    Royal Palace
    28
    9,339
    saudis like only three cars & one jeep
    1. Toyota Camry
    2. Chevrolet Caprice
    3. Ford Crown Victoria
    & the jep 4x2 GMC Suburban 1400
    pakij2000's Avatar
    Jul 2004
    Attock
    35
    6
    chevrolet caprice stoped production in 1996.but crown vic is still available. Crown vics are fast as hell . used by american police.
    JumboJet's Avatar
    May 2004
    Royal Palace
    28
    9,339
    ya crown victoria also uses saudi police in their fleet but here in saudia arabia & other GCC countries every year new chevrolet caprice availbal. in america chevrolet caprice production stopped but not here in gulf countries
    this is the 2004 chevrolet caprice royale
    2005 TOYOTA CAMRY -616673
    pic from balubaid
    www.balubaid.com
    kewlsolara's Avatar
    Sep 2003
    Melbourne
    39
    822
    Caprice is still being produced in Australia under the Lable Holden Caprice and is being exported to Gulf.
    http://www.holden.com.au/www-holden/action/modeloverview?modelid=8000
