I like Hummer H1 & H2
General
Manufacturer Hummer
Model H2 2003
Powertrain Layout Front Engine / Full-Time 4WD
Dimensions
Length 4819 mm / 189.7 in
Width 2062 mm / 81.2 in
Height 1977 mm / 77.8 in
Wheelbase 3118 mm / 122.8 in
Weight 2909 kg / 6,413 lbs
Front / Rear Track F 1762 mm / 69.4 in
R 1762 mm / 69.4 in
Engine
Configuration 6.0 Liter Vortec 6000 V8
Valvetrain OHV
Displacement 5967 cc / 364.1 cu
Power 242.4 kW / 325.1 bhp at 5200 rpm
Torque 522 Nm / 385.0 ft lbs at 3600 rpm
Bore 101.6 mm / 4.0 in
Stroke 92 mm / 3.6 in
Compression Ratio 9.4:1
Bhp / Liter 54.47 bhp
Chassis & Body
Steering Recirculating Ball w/ Integral Power
Brake Type Dual-Piston Calipers w/ Dynamic Rear Proportioning & Four-Channel ABS
Wheels F 43.2 x 21.6 cm / 17.0 x 8.5 in
R 43.2 x 21.6 cm / 17.0 x 8.5 in
Tyres F 285/70R-17
R 285/70R-17
Transmission
Gear Type 4 Speed Automatic
Final Drive 3.06:1
1st Gear Ratio 1.62:1
2nd Gear Ratio 1:1
3rd Gear Ratio 0.69:1
