[highlight]
After only collecting the headings... here's the Summary..... WAIT FOR MY COMMENTS... Coming Soon!
Proper tire inflation
Checking tire inflation
Fuel economy varies with tire type
Don't Carry More Than You Need
Remove That Rack
Retain That Tailgate
Maintaining Your Vehicle
Schedule Regular Maintenance
Follow The Schedule
Emissions and Fuel Economy
Look, Listen, and Sniff
Additional Maintenance Tips
Know What's Under the Hood
Read About Your Vehicle
Change the Air Filter
Check and Change the Oil Regularly
Maintain the Cooling System
Check Belt Tensions
Check Belt Tensions
Inspect the Battery
Consider an Engine Block Heater
Pay Attention to the Brakes
Maintain Wheel Alignment and Tire Balance
Steer Clear of Gimmicks
Planning Your Route
Use the Multi-Car Family Advantage
Investigate Alternative Routes
Drive When Others are not Driving
Drive Where Others are not Driving
Consider Weather Conditions
Dress Right
Explore Alternative Forms of Transportation
Gas-Saving Tips
Practice Mind Over MPG
Reconsider Remote Starters
Fill the Tank Only When Needed
Buy Gas on Cool Mornings
Gas Up Along the Way
Know Your Car's Correct Gasoline Octane Rating
Fuel-Efficient Driving
Lose Traction, Lose Fuel
Consider RPM and MPG
Shift Smartly
Take Advantage of the Upshift Light
Watch the Tachometer
Skip an Occasional Gear
Get the Most from Your Automatic Transmission
Watch That Little OD Light
Make Sure Nothing's Afoot
Saving Gas While Standing Still
Shift to Neutral When Stopped
Shut off the Engine When Stopped
Don't Race the Engine at Stoplights
On an Upgrade, Hang on With the Brake
Shut Down When You Leave the Car
Park it Sooner
Don't Rev the Engine Before Shutting Off the Ignition[/highlight][u][/u]
Original Reply By : Salarzae
DT : 11/16/2006 1:21:37 PM
