This is called TOYOTA CORONA RT-134
Bodystyles: 4-Dr Wagon, 4-Dr Sedan, 4-Dr Liftback.
Engine: 20R. 2.2L Inline 4.
The 2-valve SOHC 2.2 L (2189 cc) 20R was produced from 1975 through 1980.
Cylinder bore was 88.4 mm (3.48 in) and stroke was 88.9 mm (3.5 in).
Initial output was 96 hp (72 kW) at 4800 rpm and 120 ft·lbf (162 N·m) at 2800 rpm. Power was down slightly from 1978 through 1979 at 95 hp (71 kW) at 4800 rpm and 122 ft·lbf (165 N·m) at 2400 rpm. The final version, from 1979 through 1980, was down again at 90 hp (67 kW) at 4800 rpm and 122 ft·lbf (165 N·m) at 2400 rpm.
Transmissions: 3 Speed Automatic, 4 Speed Manual, 5 Speed Manual.
Drivetrains: Rear Wheel Drive.
