Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Like Tree13Likes
Thread: Suzuki GS-150 Alter in Sprocket
    zaidi62's Avatar
    Mar 2011
    13
    Default Suzuki GS-150 Alter in Sprocket
    Salams All, I would like an alteration by front and rear sprocket in my Suzuki GS-150 2008 sealed engine, for get enhance acceleration & top speed also, stock in GS front 15 teath and rear 41 teath, front is not like common as install with 2 or 3 bolts it has only center big nut covered driving shaft which has smaller gears male/female. I want to replace them with 16~17 teeth front and 36~38 teeth rear. Any experience user have any idea for replace or reputed mechanic in Karachi area..??
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    More than a mechanic u need to find suitable parts as per ur requirment. The Sprocket fitting mechanisim is almost same on all Suzuki Bikes & almost in all old model Big bikes. SO u may find some suitable stuff from Junk (Renchore Lane Market).
    Exploring Machines is my Passion...
    h3llzang3l's Avatar
    Jan 2011
    Multan
    76
    i don't have good experience with the change of it ... you get the acceleration in first 3 gears and then...... every thing goes down.. coz the Engine RPM respond as per factory defaults .. if you want to fit these in your bike then your Engine RPM needs to Perform faster then the factory setting...
    adeelmatrix's Avatar
    Jul 2006
    35
    23
    Salam,
    Don know about GS exactly that how much top speed it can go on factory default...but what i've observed that GS150 did'nt provide that much torque then CG 125 and CB 150..Specially CG can give a real hard time at it's top speed...if u wanna try then i suggest these specification: Front 16T - Rear: 40T OR As per my suggestion i think it will give your more result if your piston can handle it: Front: 15T - Rear: 40T...Try them and do provide feedback.
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @zaidi dear alterations in sprockets express 2 kind of results
    you cant have much acceleration+top speed by a modified sprockets set
    first of all u will have to make a mind,do u need top speed or the acceleration?
    i have some calculations that will help u in it....
    your bike has 15/41 its stock and its reduction ratio is 2.73
    if u need top speed then try a set of 15/38, its reduction ratio will be 2.53...
    it means lower the reduction ratio increase the top speed
    but
    its also has limits
    and higher the reduction ration creates much accelerations and it will decrease the top speed
    if u use 15/45 its ratio is 3.0 that will increase ur accelerations but it will kill ur speed
    u can also have lower reduction ratio but having one more teeth in front sprockets as @adeelmatrix described 16/40 set of sprockets and it has also 2.5 of reduction ratio,this set will must increase ur top speed but it will also kill ur accelerations too.....
    so as per my exp if u need top speed with stock accelerations the go fo 15/38
    thanks
    ***SPEED+ACCURACY+AGGRESSION=YAMAHA RX115***
    zaidi62's Avatar
    Mar 2011
    13
    salaams. and thanks all of u for response n suggestions, in the lights of all ur comments i got that any replacement of stock will be demand sacrifice in shape of dwon side acceleration or top speed. to find sprocket for front with 16T is also a problem for it. what will be get difference if remain front as its is stock n install only rear for 38/36T..? will it good combination..? and another thing will it can give better result in fuel efficiency in km p/ltr..?
    Regard
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    Quote Originally Posted by zaidi62 View Post
    Regard
    with 15/38
    top speed will increase
    acceleration will remain same as stock
    1st,2nd gears ratio will have been change (bike will feel lil softer)
    rpm will be lil lower then earlier in final gear and it will suite u for lil long distance travel and it will also effect on ur fuel eco in positive
    abdulrehman1115's Avatar
    Feb 2015
    18
    Spoket 38t karachi me kaha se milta hyy
    Feb 2015
    18
    Yar ye 38t spoket kaha se mily ga
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    Just for everyones info.. gs has a 15-43 setup
    Feb 2015
    18
    I want gs rear 38t spoket in Karachi ..plz guide Mee....
  12. #12
    junaidakhtar01's Avatar
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    Quote Originally Posted by RX115 View Post
    but
    its also has limits
    thanks
    Jis jis ne gear wali cycle chalai hai wo is baat ko asani se smjh skta hai...
  13. #13
    Feb 2015
    18
    Wo to sai hy gear wali cycle ka scene lakin ap imagin 150 me Bohout bara spoket dal dia hy uske ke bad isko 1 kilometers chahain or phir ap khud samajh Jain gy 1..
  14. #14
    Feb 2015
    18
    150 me hero Honda 125 ka 38t spoket lagjata hy koi Mjy btaii hero Honda ka rear poker kahan se mily ga
  15. #15
    Feb 2015
    18
    Yar ye 38t spoket mily ga kaha se????
    with 15/38
  16. #16
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    Dhoondnay say to ALLAH be mil jata hay yay to only Sprocket hay
  17. #17
    Feb 2015
    18
    Finally I bought suzuki gs 150 spoket 38t in 800 ruppes Andoni intereses bike Bohout Zabardast ho gai esa lag raha hy 500 cc engine chala raha hun na to koi bhari pan Naw koi prob suzuki walo ne is bike ka spoket Bohout bara diya hyy so i change igt
    Quote Originally Posted by hamikhan View Post
  18. #18
    tahirahmad13's Avatar
    Dec 2009
    Gujranwala
    827
    3 Post(s)
    It means a common Pakistani is better engineer than Japanese engineers of Suzuki!
  19. #19
    onefifty's Avatar
    Oct 2013
    155
    20 Post(s)
    the top speed will be lowered down with 38T? Since you said it is just like 500cc now....
  20. #20
    haseebcool's Avatar
    Oct 2009
    31
    Quote Originally Posted by abdulrehman1115 View Post
    Yeah i change it too.....
