Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 112
Like Tree90Likes
Thread: Suzuki GS-150 2012
    junaidakhtar01's Avatar
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
  2. #81
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    @JunaidAkhter Why do you recommend to change the whole front suspension for installing front Discs? Why Change the Front Shocks? Will not replacing the drum of Classic to deluxe or any other Dics Brake bike will suffice?
    Whats your take on Chinese Disc Brakes, New cost around Rs.2k?
    Bikes don't leak oil, they mark their territory.
  3. #82
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    Quote Originally Posted by aximaxim View Post
    But few mechanics told me that GTO suspension rods are thick as compare to CG and for this you have to change the front frame of CG.
  4. #83
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Junaid Sahab GTO brand new shocks along with disc are available or i have to search something from junkyard?
    Dream is not that which you see while sleeping it is something that does not let you sleep.
  5. #84
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    sir brand new to nai milte
    aik solution ye hai k old shocks lekar new shafts+new springs dal di jain
    like i did to my gto
    seal size hai shaft dai is same as gs150
    aur gs150 ki new shafts available hen
    see at the end of this page
    https://www.pakwheels.com/forums/bik...gto-125-reborn
  6. #85
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    Meri neend ujaardne wale . . .
    Ab tere khuwab kon dekhe ga . . .!
  7. #86
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    bro cg,s front n rear suspension is much harder...will not perform good on disk brake.....rather gto,s forks are made for disk set up and its is much softer n have much travel for disk braking.....on cg,s fork, bike will must skid on disk braking, due to hard (front n rear)suspensions
    ***SPEED+ACCURACY+AGGRESSION=YAMAHA RX115***
  8. #87
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @r1 bro gto,rx fork inner tube diameter is 30mm and i think cg,s inner tube is 28mm
    thats why T will be replace. or if u can over bore(2mm) cg,s T from inside then n same original T u can also put gto,s fork, but make it sure k T over bre honay ki wjha se thin na hojay........mean if there is much place for over boring the T holes then do it,
    doing this you will feel much easy, coz if you put gto,s T then lil issue of race ball fitting will must appear.......
  9. #88
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    front fender support
  10. #89
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    current pics with front fender support
  11. #90
    racer7's Avatar
    Oct 2012
    1,578
    5
    40 Post(s)
    7 Thread(s)
    Junaid bhai, Can the disc brakes be installed on Pridor?
    Will you please guide me by providing me the procedure?
  12. #91
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    Quote Originally Posted by racer7 View Post
    use kawasaki disk brake system if pridor shocks shafts are same as kawasaki than it will be so easy
  13. #92
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Junaid what are your thoughts about installing 17inch 70cc alloys rims in Pridor
    as there is not 18inch alloys available for pridor in market
    Will it effect very badly on pridor, i mean kiya bike ki height kaafi kam hojaaege
    ya buhat thorha faraq aaega. i talked with some mechanics here @ my city
    all discouraged me they said it will ruin bike performance small 70cc alloys & tyre would look ugly on pridor
    Suzuki GS-150 2012 - K85cqER
  14. #93
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    amjad bhai they r right
    height k ilawa speed bhi kam hojayegi
    aur phr alloy without disk brake koi faida nai hai
    aap kis city se hen ahore mein to bilal ganj kafi famous hai
  15. #94
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    CTRL + Q to Enable/Disable GoPhoto.it
  16. #95
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    how many of us want to feel the rain, and how many of us just want to get wet ?
  17. #96
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    mujko ye aarzu, wo uthain naqaab khud
    un ko yeh intezar, taqaza kare koi
    lekin yahan kisi ne poocha hi nai
    my Suzuki GS-150 2012
    is now upgraded to the new alloy rims and disk brakes
  18. #97
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    some more pics
  19. #98
    KamranAslam's Avatar
    Apr 2006
    Select City
    14,249
    7
    295 Post(s)
    11 Thread(s)
    9
    ^^^ Junaid: One hot-shot bike you got there for others to learn an upgradation of a bike --- Gs150 to its peak-looks. ... GodSpeed.
    I am only responsible for what I say, not for what you understand..
  20. #99
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    some most important and breath taking features of this modification
    Original chain cover on its original placement
    Original sprocket Hub with original sprocket
    Front 18 Rear 18 as per original specs.
    Original front suspension is placed (Never disassemble these shocks)
    Original front mudguard is placed
    Rims and Disk brake system is Originally Made in Japan and originally Suzuki
  21. #100
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
