Page 15 of 29 FirstFirst ... 5131415161725 ... LastLast
Results 281 to 300 of 574
Like Tree564Likes
Thread: Suzuki GS150 Euro-ll 2013
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,276
    90 Post(s)
    7 Thread(s)
    Cool Suzuki GS150 Euro-ll 2013
    Hi everybody
    Here is my new ride GS150.
    This is my second GS. I got Deluxe after selling the first one, but started missing the silent and smooth ride of GS so got one again.
    Please say Mashallah
    Suzuki GS150 Euroll 2013 -1693389
  2. #281
    Shafin619's Avatar
    Sep 2012
    21
    2,699
    95 Post(s)
    2 Thread(s)
    Quote Originally Posted by nom125 View Post
    I know it`s poor mileage, but i think main cause could be carburetor. another reason could be that at speed of 60 kph engine sounds as if it is on full throttle
    Bro fuel mixture check karwao aur carb ki tuning karwao.
  3. #282
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,276
    90 Post(s)
    7 Thread(s)
    Same is my case , i use GS 150 for fun and longer routes and CD 70 for use in heavy traffic. Ironically both are giving me identical mileage
    Gs 150 is currently giving 38 kpl
    Cd 70 after ring piston change is giving me 40 kpl on race mode (50 kpl when there is lesser traffic and on gentleman mode)
    petrol pump change kar ke bhi check kar lo
  4. #283
    nom125's Avatar
    Dec 2012
    253
    2 Post(s)
    Quote Originally Posted by Shafin619 View Post
    Fuel mixture i tested was rich , how i know because i cleaned spark plug and drove it 2-3 km and when i again opened it , it was black , mixture i set myself repeating the same test
    Was satisfied when color changed to somewhere between brown and red like rust
  5. #284
    nom125's Avatar
    Dec 2012
    253
    2 Post(s)
    Quote Originally Posted by gull_s_777 View Post
    Will give this a go, however pump used is pso near services hospital and shell at model town more, both have good reputation in terms of quality and i also make sure they don`t rob me in terms of quantity
  6. #285
    fawadbaig's Avatar
    Oct 2013
    37
    I did the following experiments:
    1- Using different grades of oil like HX7 (5W-15) but the engine started to heat up because the oil was thin then used HX5 (10W-40) again which fixed the heat up problem.
    2- Tuning the fuel mixture to 5 rotations gave me a great top speed and pick.
    3- Making the suspension stiffer solved my lose chain issue and made the bike more stable in drag race. However I change the suspension soft when going on long drives.
    The initial pick of GS150 won't be great until first 4000 KMs but once you are done with the first 4000 KMs even CG125 can not beat you in initial pick. (Using the stock tyres)
    The performance of the bike depends on the first 1000 KMs and the way one breaks in the engine. (Please read MotoGP guide on how to break-in your new engine).
    I was thinking to install a HID on the stock battery, please let me know if anyone have done it. Does it affect the battery? and is the Self working properly?
  7. #286
    SyedMoazzam's Avatar
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Quote Originally Posted by fawadbaig View Post
    Yar how do you change suspension settings
    And please do not use HID's in reflector housing, it will blind others on the road which makes night driving very difficult for other people
    Get a proper projector housing if you really want to install an HID
  8. #287
    fawadbaig's Avatar
    Oct 2013
    37
    Quote Originally Posted by SyedMoazzam View Post
    If you look at the rear shock absorbers, there is a rotator which can be used to make the suspension soft/hard.
  9. #288
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Which tool should i use to rotate them
  10. #289
    moons's Avatar
    Apr 2013
    33
    1,483
    39 Post(s)
    4 Thread(s)
    bro dont u know about these adjustable shocks in gs,piaggio and dlx?just ask a suzuki machanice he will do it in just 4 or 5 seconds with a big special wrench.
  11. #290
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Quote Originally Posted by moons View Post
    I know about it magar kbi zrurat he nai parti
    Plus i wanted to do it by myself
  12. #291
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    Just grip the lower portion of shock firmly and twist it
    Sent from my GT-I9300 using PW Forums mobile app
  13. #292
    getscorpion's Avatar
    May 2009
    33
    2,699
    15 Post(s)
    2 Thread(s)
    u don't need any special tool ... i hv always adjusted mine with big wrench .. just fix the wrench on the ring lower to spring and turn clock wise ... if u want to fix it on previous setting then just make a full rotation clock wise ... that's it !
    Suzuki GS150 Euro-ll 2013 - images?qtbnANd9GcQSSqKG3uX3ROHCouf5vQtEmkzgoRSOrje143NXlm1yGyzY7aYqNQ
    Rise from the ashes,.....
  14. #293
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Hmm ok thanks for the info
  15. #294
    waqas18's Avatar
    May 2006
    28
    1,501
    23 Post(s)
    3 Thread(s)
    Quote Originally Posted by getscorpion View Post
    I just used screw driver..
    People with high ego and unnecessary attitude deserves the standing ovation of the tallest finger..
  16. #295
    fawadbaig's Avatar
    Oct 2013
    37
    This is the tool to adjust the suspension.
    Suzuki GS150 Euroll 2013 -1292254
  17. #296
    dmszack's Avatar
    Jan 2013
    631
    17 Post(s)
    Hi all, Meri bike 80+ per chaal marti hai jese kuch dheela ho iska and aaj suddenly front shockers ki smoothness gayab hogai jese handle from T is loosen ??? What could bethe problem ?? ?
  18. #297
    fawadbaig's Avatar
    Oct 2013
    37
    Quote Originally Posted by dmszack View Post
    How much have you driven your bike? Get the bolts tightened.
  19. #298
    kenreaves's Avatar
    Oct 2013
    Hyderabad
    11
    awesome bike <3
  20. #299
    dmszack's Avatar
    Jan 2013
    631
    17 Post(s)
    1200 ... at 1000 i have told 3s mechanic to tight all the bolts .
  21. #300
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    The point to be noted is that each and every nut and bolt of a vehicle must not be either too loose or too tight
    For this purpose the manufacturers specify the torque readings in the manual for each nut and bolt and for this purpose a torque wrench is to be used by the mechanics
    but unfortunately in this country no mechanic has knowledge of this thing since the companies do not mention these settings in their product manuals
    Over tightening a bolt also has dire consequences at high speeds
