Page 9 of 17 FirstFirst ... 7891011 ... LastLast
Results 161 to 180 of 333
Like Tree266Likes
Thread: 2 Suzuki GD110 On Pakwheels :)
    shedatali's Avatar
    May 2013
    292
    3 Post(s)
    Default 2 Suzuki GD110 On Pakwheels :)
    Here is my new Metallic Silk Red Gd110...
  2. #161
    zeshanaslam's Avatar
    Oct 2010
    Faisalabad
    113
    2 Post(s)
    ^^ I think thay are not meant for 90KM/H. Its mean that don't go above 3/4 of the total throtle circulation in any gear. In urdu, kabhi b full race na do engine ko, sirf 3/4 tak he rakho during break-in period.
  3. #162
    shedatali's Avatar
    May 2013
    292
    3 Post(s)
    Today I called Suzuki help line and asked for the maximum speed in break in period. He said gradually increase the maximum speed like in first 100km. do not go more then 40, then in next 100km to 200km 45KM/h to 50 Km/h . He also said if you wana drive it on more speed then you can do it as its engine is capable for this BUT do not give quick acceleration . Change the oil plus filter after 1000KM as recommended in manual.
    Personally I think its better if we change the first oil around 500Km and increase the maximum speed after every 100 km. like
    First 0km – 100km drive it 35 to 40 km per hour
    101km – 200Km drive it 40 to 45 Km per hour
    201 km – 300Km drive it 45 to 50km per hour
    301 km – 400 drive it 45 – 55
    After oil change drive it to 60 km /h
    What you people said..?
  4. #163
    IADina's Avatar
    Sep 2012
    161
    6 Post(s)
    Quote Originally Posted by shedatali View Post
    First 0km ? 100km drive it 35 to 40 km per hour
    101km ? 200Km drive it 40 to 45 Km per hour
    201 km ? 300Km drive it 45 to 50km per hour
    301 km ? 400 drive it 45 ? 55
    You are right. After 1st oil change I felt if I go on 45 km/h on 4th gear, the engine feels a little lag now as I've done 600kms I normally go on 60km/h on 4th gear.
    Proud 1st Owner of Suzuki GD110 on PW.
  5. #164
    shedatali's Avatar
    May 2013
    292
    3 Post(s)
    Quote Originally Posted by IADina View Post
    i just touced 300 today...
  6. #165
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    i add one thing more here,i hope you guys will already well aware about it,anyways, Do not ride atc onstant same speed (chahay kitni hi low bhi kiu na ho) during brake inn process, rather speed should be changed from low to mid at regular basis, and do not run at same speed for long time, thanks
    ***SPEED+ACCURACY+AGGRESSION=YAMAHA RX115***
  7. #166
    TZB
    TZB is offline
    TZB's Avatar
    Sep 2010
    28
    691
    60 Post(s)
    2 Thread(s)
    Question
    shedatali, and IADina (I hope I spelled it correctly now ), please tell me about its gear shifting experience.
    When I had its test drive a few weeks ago, I didn't do a long loop so I couldn't figure out how good is its gear shifting mechanism. Frankly speaking, I found it a bit "hard". I mean to say, gear shifting didn't feel smooth.
    Can you guys please share your experience?
    First deserve, then desire.
  8. #167
    shedatali's Avatar
    May 2013
    292
    3 Post(s)
    Quote Originally Posted by TZB View Post
    i think that due to new parts.. but i personally think, they are not so hard to shift ..
  9. #168
    shedatali's Avatar
    May 2013
    292
    3 Post(s)
    Quote Originally Posted by RX115 View Post
    thanks ...yup.. i am doing same..
  10. #169
    md
    md is offline
    md's Avatar
    Jul 2007
    26
    28
    Have been reading these threads for hour.Feels good to have new technology in PK. Specially by Suzuki in recent months,
    Any one plz share performance figures top speed acceleration gearing ratios and economy.
  11. #170
    UmairDrive's Avatar
    Sep 2010
    22
    Quote Originally Posted by raxaengineer View Post
    2 Suzuki GD110 On Pakwheels  -12029272 Suzuki GD110 On Pakwheels  -1202928
    WTF
    see the price difference of indian & pakistani bike?
    yaar ye keun PS walay hmein loot rhein hein?
    kya PS, AHL ,DYL ye sb milay huye hein ?
    Please also see the quality style & perfomance of these bikes.
    Indian 110 cc bike SLing Shot Price in Indian Rupees 54474 Price in PKR 92239.70
    Indian 110 cc bike Hayate Price in Indian Rupees 42274 Price in PKR 71581.69
    Please give your suggestions
    Bro its natural.. ap exchange rate dekho ..and economy dekho.. hell of difference.. yahan engine bahir say ata ha...waha they manufacture engine.. waha economy of scales ki waja say production cost kum..and yaha ..bht...so yeh companies naih sub loot rahay
  12. #171
    shedatali's Avatar
    May 2013
    292
    3 Post(s)
    Default new updates
    my bike ... eco friendly...
  13. #172
    shedatali's Avatar
    May 2013
    292
    3 Post(s)
    Default more
    more pics
  14. #173
    TZB
    TZB is offline
    TZB's Avatar
    Sep 2010
    28
    691
    60 Post(s)
    2 Thread(s)
    Superb! Beautiful pictures, Masha Allah.
    Keep more coming.
    I wonder what part of Lahore you clicked these pictures in :-/
  15. #174
    dr.omair's Avatar
    Aug 2010
    31
    583
    224 Post(s)
    9 Thread(s)
    its probably on the canal road that goes from thokar all the way to bahria....am i right?
  16. #175
    mtmoghul's Avatar
    Apr 2009
    609
    7 Post(s)
    3 Thread(s)
    Allah Mubarak Kare
  17. #176
    shedatali's Avatar
    May 2013
    292
    3 Post(s)
    Quote Originally Posted by dr.omair View Post
    yup right..
  18. #177
    TZB
    TZB is offline
    TZB's Avatar
    Sep 2010
    28
    691
    60 Post(s)
    2 Thread(s)
    The sooner I get my GD 110, the sooner we'll shoot both of the beauties together!
  19. #178
    shedatali's Avatar
    May 2013
    292
    3 Post(s)
    Sure i love to.... Also try to get any LAL prider with us
  20. #179
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    mashAllah beautiful pics pleasant to watch GD looking
    & from rear it looks very attractive & sporty
    But bro please don't underestimate Pridor in looks
    its very attractive looking if pridor stand besides GD
    your GD may start to look ugly to you
    And I Really Want To Know Top Speed Of GD110
  21. #180
    TZB
    TZB is offline
    TZB's Avatar
    Sep 2010
    28
    691
    60 Post(s)
    2 Thread(s)
    Wake up guys, shedatali and IADina! You must have clocked 1,000 km+ on your GDs. Time to rev 'em up! How fast has it taken you yet? How does it respond when you open its throttle?
Tags for this Thread
