Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 101 to 120 of 183
Like Tree78Likes
Thread: Improving the Performance of you Suzuki GS-150
    12gauge's Avatar
    Oct 2013
    176
    68 Post(s)
    3 Thread(s)
    Default Improving the Performance of you Suzuki GS-150
    AoA Everybody.
    I would request all Suzuki GS-150 owners to discuss typical performance issues with their bikes and how they resolved them. this way, we'll have a collection of information here for the benefit of newbies such as myself and hopefully, other bike owners will also profit from it.
    Improving the Performance of you Suzuki GS-150 - Pic3 zps51edbf85
    Following problems/issues has been identified so far:
    1. Less than ideal performance of the ignition system
    2. High tendency of the bike to break speedometer and rpm cables.
    3. Loud (Tuck!) noise from rear wheel and less than ideal gear shifting.
    4. Faulty/Finicky fuse.
    Poor performance of the ignition system:
    Improving the Performance of you Suzuki GS-150 - Pic5 zps6f7688f3
    The factory /EM coil provided with GS-150 is not up to mark. I replaced it with Honda Deluxe's ignition coil (DENSO) and the quality of the spark improved. then I installed a platinum spark plug (NKG CR8EGP) and instantly experienced better throttle response and stable idling. on top of all that the bike's cold starting ability also improved significantly.
    Then I read an article where the author was recommending spark plug indexing in a bid to aim the open end of the spark plug's tip somewhere in between the intake and exhaust valve of the engine for better performance. BOY! it was some exercise but the results made it all the worth while. the throttle feels much lighter than before, the bikes accelerates better than before and the idling is as stable as the heart beat of a monk.
    now someone might ask why not Iradium? well....contrary to popular belief, Iradiums do not offer any performance benefits over Platinums. they just offer increased/longer life. so why spend three times as much when you can get the same benefits from Platinum plugs?
    high tendency of the bike to break speedometer and rpm cables:
    Improving the Performance of you Suzuki GS-150 - Pic4 zps2ae8ee70
    I was getting kinda tired of casual breaking of the speedometer and RPM cables. I know one is supposed to lubricate them with WD40 but somehow I was never convinced that a simple CLP (cleaner, lubricant, protectant) would be good enough for the job. the problem with oil is that it eventually migrates from the place where it is applied. Then I stumbled upon this:
    NASA Liquid Grease
    Its a solvent based lithium grease packed in a pressurized container. which means that it can penetrate to the desire spot then solvent evaporates leaving behind a uniform film of lithium grease. pretty neat concept. I bought one and sprayed down the RPM and speedometer cables. I was instantly sold. Now I use it on clutch and throttle cables as well. Guess what? the Speedometer and RPM cables haven't broken since then and clutch and throttle stay lubricated longer.
    Loud (Tuck!) noise from rear wheel and less than ideal gear shifting:
    Improving the Performance of you Suzuki GS-150 - Pic1 zps2f2cb105
    Loud noise as it turned out was from rear drum as the drum rubber was not a tight fit. just for the sake of killing a few million brain cells solving this problem I approached a guy who makes custom drum rubbers and voila! no more sound and the gear shifting is now as smooth as silk. I don't know how it made the gear shifting smooth but it did. now shifting the gear up and down do not produce any jerk or noise.
    Faulty/Finicky Fuse:
    Improving the Performance of you Suzuki GS-150 - Pic8 zpsc9fdb1c3
    The OEM ignition fuse provided with the bike is nothing more than an outdated piece of cheap contraption. I learned that the hard way. I was on my way (to nowhere) and the bike suddenly totally went dead on me. nothing would work. luckily, Suzuki Center was near and I took the bike there and it started without a hiccup. I moved on then one fine day it happened again. I took the bike to the same guys and the bike started again without any problem. then the mechanic told me that I should get the fuse replaced with a car fuse of equal ampere. I took the the bike to a car electrician who installed a proper car fuse and charged me just Rs. 100 (including the price of the fuse box and wiring) no trouble since then.
    Improving the Performance of you Suzuki GS-150 - Pic9 zpsf4ade752
    Anyhow, thats how I went about solving some of the issues with my bike. if you guys have identified any other issue and successfully resolved it, kindly do share with all of us.
    Regards.
  2. #101
    rai007's Avatar
    Nov 2010
    73
    9 Post(s)
    here is the proof about the handle alignment issue.
    Q: https://www.facebook.com/groups/1436...0327242823539/
    Ans: https://www.facebook.com/groups/1436...al_comments=97
    actually i will recommend every one to read this conversation if you have 2014 suzuki gs 150,
  3. #102
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    Quote Originally Posted by rai007 View Post
    now what if tell u that i had faced this problem too during break in period of my ride and at 1k check at suzuki UR it was and couple of other problems were rectified .
    cheer up brother go to suzuki UR and ask for the same mechanic i mentioned in my previous post he will fix this problem.
    if u have difficulty in identifying that mechanic ask them for the 1 who worked on bike which have studds side box and helmet lock on it or asked jamshed abt it, jamshed knows me well.
    its them who should be worried not u
    good luck
    Help others so that u can be Helped
  4. #103
    rai007's Avatar
    Nov 2010
    73
    9 Post(s)
    Quote Originally Posted by archon2001 View Post
    good luck
    Sure. I will visit them tomorrow UR suzuki aaddress is same which you have mentioned in previous post?
    Also may I know your name ? I hope it will be fixed.
  5. #104
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    self edited.
  6. #105
    rai007's Avatar
    Nov 2010
    73
    9 Post(s)
    self edited.
    Thank you very much sir. On Saturday I visit the ur suzuki person name was shahid. He fixed my handle alignment after all. Still little bit on left side but I can live with it. I ask him how was my bike shoot and he says sahi nahi hai. Exactly my point and he said I will fix it as well just come another day and leave the bike here.
  7. #106
    asim_khan29's Avatar
    Jan 2014
    6
    Improving the Performance of you Suzuki GS150 -1410633
  8. #107
    Jan 2014
    6
    Improving the Performance of you Suzuki GS150 -1410634
  9. #108
    Jan 2014
    6
    Default Gs-150
    above images are of my gs-150 that is modified by me
  10. #109
    mianasadqadeer's Avatar
    Apr 2014
    162
    6 Post(s)
    Quote Originally Posted by asim_khan29 View Post
    Wah G wah akheer mOdificatons (y)
    Sent from my iPad using Tapatalk
  11. #110
    Sniper's Avatar
    Apr 2005
    30
    198
    3 Post(s)
    From where can I get this chain cover/guard from??
    I'm from Karachi btw
    Sent from my SM-N9006 using PW Forums mobile app
    Eat - Sleep - Drive
  12. #111
    SyedMoazzam's Avatar
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Total cost?
  13. #112
    Jan 2014
    6
    approx 60k
  14. #113
    iffinca's Avatar
    May 2012
    37
    35
    Hi guys ..... after reading this all thread i came to conclusion that i should drop the idea of buying gs 150 and buy another CG125 .... whats your suggestions friends ...... the only gud thing i like in Gs 150 is conformtable ride (i have little bit lower back pain issue). we (three/ four) friends wanted to go on a long trip to .naran , chilla ,sakardu or deosei ..... from Lahore ... InshaAllah . Two years back we have done Lahore Naran , Saif ul Maluk ---- Naitha Gali and than Lahore ... trip . What i came to point is CG 125 is gud in power and acceleration but riding it on long trip is so tiring ....
  15. #114
    tucknoloji's Avatar
    Jan 2010
    35
    572
    22 Post(s)
    2 Thread(s)
    Quote Originally Posted by iffinca View Post
    dear on long ride... gs150 is far more better than cg125.... gs150 is better to maintain constant maximum speed and cools down v quickly... niose free and will not give u any headache like cg125... moreover fuel avg even clocking at high rpm will remain economical... call is urs
    Sent from my Galaxy Nexus using Tapatalk
  16. #115
    iffinca's Avatar
    May 2012
    37
    35
    Thanks bro ... I agree with u that for long trips gs is better than cg ....
  17. #116
    Sniper's Avatar
    Apr 2005
    30
    198
    3 Post(s)
    But the seat of GS is very hard!!!
    Eat - Sleep - Drive
  18. #117
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Quote Originally Posted by Sniper View Post
    100% agreed
    I am owner of GS150 since 3 years and its seat is really hard
  19. #118
    Sniper's Avatar
    Apr 2005
    30
    198
    3 Post(s)
    Quote Originally Posted by SyedMoazzam View Post
    100% agreed
    I'll make my own seat soon
    Just waiting to get some free time...
    Eat - Sleep - Drive
  20. #119
    rehansch's Avatar
    May 2013
    43
    8
    Dear GS riders,
    I am looking for a reliable bike I can use for casual rides or commuting to work in fair weather. Resale value is not under consideration. I have lately taken a strong fancy to GS as I like its looks, engine size, OHC construction but reading -ve reviews about its quality questions my love for the machine.
    Since u hv been riding the GS and hv hands on experience, pls need yr honest advice and verdict in thia machine. Pak Suzuki's interest free instalment offer makes the machine even more tempting. But then I also need peace of mind ...
  21. #120
    Ishaqueahmed's Avatar
    Mar 2011
    from Where we can buy the custom drum rubbers in Rawalpindi/Islamabad?
