Page 8 of 10 FirstFirst ... 678910 LastLast
Results 141 to 160 of 183
Like Tree78Likes
Thread: Improving the Performance of you Suzuki GS-150
    12gauge's Avatar
    Oct 2013
    176
    68 Post(s)
    3 Thread(s)
    Default Improving the Performance of you Suzuki GS-150
    AoA Everybody.
    I would request all Suzuki GS-150 owners to discuss typical performance issues with their bikes and how they resolved them. this way, we'll have a collection of information here for the benefit of newbies such as myself and hopefully, other bike owners will also profit from it.
    Improving the Performance of you Suzuki GS-150 - Pic3 zps51edbf85
    Following problems/issues has been identified so far:
    1. Less than ideal performance of the ignition system
    2. High tendency of the bike to break speedometer and rpm cables.
    3. Loud (Tuck!) noise from rear wheel and less than ideal gear shifting.
    4. Faulty/Finicky fuse.
    Poor performance of the ignition system:
    Improving the Performance of you Suzuki GS-150 - Pic5 zps6f7688f3
    The factory /EM coil provided with GS-150 is not up to mark. I replaced it with Honda Deluxe's ignition coil (DENSO) and the quality of the spark improved. then I installed a platinum spark plug (NKG CR8EGP) and instantly experienced better throttle response and stable idling. on top of all that the bike's cold starting ability also improved significantly.
    Then I read an article where the author was recommending spark plug indexing in a bid to aim the open end of the spark plug's tip somewhere in between the intake and exhaust valve of the engine for better performance. BOY! it was some exercise but the results made it all the worth while. the throttle feels much lighter than before, the bikes accelerates better than before and the idling is as stable as the heart beat of a monk.
    now someone might ask why not Iradium? well....contrary to popular belief, Iradiums do not offer any performance benefits over Platinums. they just offer increased/longer life. so why spend three times as much when you can get the same benefits from Platinum plugs?
    high tendency of the bike to break speedometer and rpm cables:
    Improving the Performance of you Suzuki GS-150 - Pic4 zps2ae8ee70
    I was getting kinda tired of casual breaking of the speedometer and RPM cables. I know one is supposed to lubricate them with WD40 but somehow I was never convinced that a simple CLP (cleaner, lubricant, protectant) would be good enough for the job. the problem with oil is that it eventually migrates from the place where it is applied. Then I stumbled upon this:
    NASA Liquid Grease
    Its a solvent based lithium grease packed in a pressurized container. which means that it can penetrate to the desire spot then solvent evaporates leaving behind a uniform film of lithium grease. pretty neat concept. I bought one and sprayed down the RPM and speedometer cables. I was instantly sold. Now I use it on clutch and throttle cables as well. Guess what? the Speedometer and RPM cables haven't broken since then and clutch and throttle stay lubricated longer.
    Loud (Tuck!) noise from rear wheel and less than ideal gear shifting:
    Improving the Performance of you Suzuki GS-150 - Pic1 zps2f2cb105
    Loud noise as it turned out was from rear drum as the drum rubber was not a tight fit. just for the sake of killing a few million brain cells solving this problem I approached a guy who makes custom drum rubbers and voila! no more sound and the gear shifting is now as smooth as silk. I don't know how it made the gear shifting smooth but it did. now shifting the gear up and down do not produce any jerk or noise.
    Faulty/Finicky Fuse:
    Improving the Performance of you Suzuki GS-150 - Pic8 zpsc9fdb1c3
    The OEM ignition fuse provided with the bike is nothing more than an outdated piece of cheap contraption. I learned that the hard way. I was on my way (to nowhere) and the bike suddenly totally went dead on me. nothing would work. luckily, Suzuki Center was near and I took the bike there and it started without a hiccup. I moved on then one fine day it happened again. I took the bike to the same guys and the bike started again without any problem. then the mechanic told me that I should get the fuse replaced with a car fuse of equal ampere. I took the the bike to a car electrician who installed a proper car fuse and charged me just Rs. 100 (including the price of the fuse box and wiring) no trouble since then.
    Improving the Performance of you Suzuki GS-150 - Pic9 zpsf4ade752
    Anyhow, thats how I went about solving some of the issues with my bike. if you guys have identified any other issue and successfully resolved it, kindly do share with all of us.
    Regards.
  2. #141
    shahzadkhan222's Avatar
    Sep 2014
    Default Suzuki Official Service Centre In Islamabad/Pindi ??
    Hello,
    is there any suzuki official service centre in islamabad or pindi ??
    I've visited about two to three but they all say these are sales showrooms and do not offer repairing or mechanic services.
    Please can anyone tell me where to go to get my bike repaired ??
    Any Official Suzuki Service centre or atleast some trusted and experienced mechanic for Suzuki GS 150 ??
  3. #142
    alkandar's Avatar
    Mar 2006
    653
    7 Post(s)
    2 Thread(s)
    Quote Originally Posted by 12gauge View Post
    AoA Everybody.
    NASA Liquid Grease
    Regards.
    MasaAllah Very Nice Good Looking Bike, Simply awesome.
    alkandar
  4. #143
    the47man's Avatar
    Sep 2012
    Abbotabad
    7
    How did you raise the front forks buddy?
  5. #144
    12gauge's Avatar
    Oct 2013
    176
    68 Post(s)
    3 Thread(s)
    Quote Originally Posted by the47man View Post
    Check your personal messages bro.
    Regards.
  6. #145
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    Quote Originally Posted by ahsan95 View Post
    A small issue in my bike (Suzuki GS150)
    Bike has clocked 1700 km. While driving at a constant speed say 40kmph or 50kmph bike 'jhatke marte hai'. I am not doing anything with the throttle it just happens automatically. It's just like when you are running very low on fuel which is not the case coz bike has plenty of it.
    Engine oil is due for change at 2k mark along with tuning. Will tuning and changing the oil resolve the problem or some other work is required?
    Currently using Total 20w40 engine oil.
    Kindly leave suggestions as to what can be done. Thanks.
    Battery terminal k pass jo connections hein check those connections. Loosen contacts are the actual cause of this jerk issue.
    It is Easy to hate But Love is More Powerful...
  7. #146
    abidali03214477766's Avatar
    Oct 2014
    29
    115
    Improving the Performance of you Suzuki GS150 -1489448
  8. #147
    Oct 2014
    29
    115
    Improving the Performance of you Suzuki GS150 -1489449
  9. #148
    Oct 2014
    29
    115
    Improving the Performance of you Suzuki GS150 -1489450
  10. #149
    Oct 2014
    29
    115
    Improving the Performance of you Suzuki GS150 -1489451
  11. #150
    Oct 2014
    29
    115
    Improving the Performance of you Suzuki GS150 -1489452
  12. #151
    Oct 2014
    29
    115
    Improving the Performance of you Suzuki GS150 -1489453
  13. #152
    Oct 2014
    29
    115
    Improving the Performance of you Suzuki GS150 -1489454
  14. #153
    Oct 2014
    29
    115
    Improving the Performance of you Suzuki GS150 -1489455
  15. #154
    Oct 2014
    29
    115
    Improving the Performance of you Suzuki GS150 -1489456
  16. #155
    Oct 2014
    29
    115
    Improving the Performance of you Suzuki GS150 -1489457
  17. #156
    touqeer_khan's Avatar
    Feb 2007
    11
    Hi guys,
    I was thinking to buy a new GS-150, but after going through this thread I feel i have to re-think on my decision. Please guide me if your claim/faults are removed by company or not.
    Any suggestion on buying Suzuki 150 is welcome.
    Regards,
    Touqeer
  18. #157
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    Quote Originally Posted by touqeer_khan View Post
    Hi guys,
    Regards,
    Touqeer
    If you are not in hurry to buy a bike theb wait for Yamaha to launch new bike or take a Risk of 150. But be sure you are getting fresh piece.
  19. #158
    bilalahm's Avatar
    Jan 2004
    3,045
    23 Post(s)
    7 Thread(s)
    There was a post from a member who improved the reliability of this specific bike by working on many areas like sealing the areas prone to leaks, better rust protection etc. Can anyone post the link as I cannot trace that post now
    Apart from pakwheels, my blogs can be also be viewed at http://tajziat.blogspot.com/
  20. #159
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    Quote Originally Posted by bilalahm View Post
    https://www.pakwheels.com/forums/sho...d.php?t=227387
    Here u are
  21. #160
    bilalahm's Avatar
    Jan 2004
    3,045
    23 Post(s)
    7 Thread(s)
