Page 9 of 10 FirstFirst ... 78910 LastLast
Results 161 to 180 of 183
Like Tree78Likes
Thread: Improving the Performance of you Suzuki GS-150
    12gauge's Avatar
    Oct 2013
    176
    68 Post(s)
    3 Thread(s)
    Default Improving the Performance of you Suzuki GS-150
    AoA Everybody.
    I would request all Suzuki GS-150 owners to discuss typical performance issues with their bikes and how they resolved them. this way, we'll have a collection of information here for the benefit of newbies such as myself and hopefully, other bike owners will also profit from it.
    Improving the Performance of you Suzuki GS-150 - Pic3 zps51edbf85
    Following problems/issues has been identified so far:
    1. Less than ideal performance of the ignition system
    2. High tendency of the bike to break speedometer and rpm cables.
    3. Loud (Tuck!) noise from rear wheel and less than ideal gear shifting.
    4. Faulty/Finicky fuse.
    Poor performance of the ignition system:
    Improving the Performance of you Suzuki GS-150 - Pic5 zps6f7688f3
    The factory /EM coil provided with GS-150 is not up to mark. I replaced it with Honda Deluxe's ignition coil (DENSO) and the quality of the spark improved. then I installed a platinum spark plug (NKG CR8EGP) and instantly experienced better throttle response and stable idling. on top of all that the bike's cold starting ability also improved significantly.
    Then I read an article where the author was recommending spark plug indexing in a bid to aim the open end of the spark plug's tip somewhere in between the intake and exhaust valve of the engine for better performance. BOY! it was some exercise but the results made it all the worth while. the throttle feels much lighter than before, the bikes accelerates better than before and the idling is as stable as the heart beat of a monk.
    now someone might ask why not Iradium? well....contrary to popular belief, Iradiums do not offer any performance benefits over Platinums. they just offer increased/longer life. so why spend three times as much when you can get the same benefits from Platinum plugs?
    high tendency of the bike to break speedometer and rpm cables:
    Improving the Performance of you Suzuki GS-150 - Pic4 zps2ae8ee70
    I was getting kinda tired of casual breaking of the speedometer and RPM cables. I know one is supposed to lubricate them with WD40 but somehow I was never convinced that a simple CLP (cleaner, lubricant, protectant) would be good enough for the job. the problem with oil is that it eventually migrates from the place where it is applied. Then I stumbled upon this:
    NASA Liquid Grease
    Its a solvent based lithium grease packed in a pressurized container. which means that it can penetrate to the desire spot then solvent evaporates leaving behind a uniform film of lithium grease. pretty neat concept. I bought one and sprayed down the RPM and speedometer cables. I was instantly sold. Now I use it on clutch and throttle cables as well. Guess what? the Speedometer and RPM cables haven't broken since then and clutch and throttle stay lubricated longer.
    Loud (Tuck!) noise from rear wheel and less than ideal gear shifting:
    Improving the Performance of you Suzuki GS-150 - Pic1 zps2f2cb105
    Loud noise as it turned out was from rear drum as the drum rubber was not a tight fit. just for the sake of killing a few million brain cells solving this problem I approached a guy who makes custom drum rubbers and voila! no more sound and the gear shifting is now as smooth as silk. I don't know how it made the gear shifting smooth but it did. now shifting the gear up and down do not produce any jerk or noise.
    Faulty/Finicky Fuse:
    Improving the Performance of you Suzuki GS-150 - Pic8 zpsc9fdb1c3
    The OEM ignition fuse provided with the bike is nothing more than an outdated piece of cheap contraption. I learned that the hard way. I was on my way (to nowhere) and the bike suddenly totally went dead on me. nothing would work. luckily, Suzuki Center was near and I took the bike there and it started without a hiccup. I moved on then one fine day it happened again. I took the bike to the same guys and the bike started again without any problem. then the mechanic told me that I should get the fuse replaced with a car fuse of equal ampere. I took the the bike to a car electrician who installed a proper car fuse and charged me just Rs. 100 (including the price of the fuse box and wiring) no trouble since then.
    Improving the Performance of you Suzuki GS-150 - Pic9 zpsf4ade752
    Anyhow, thats how I went about solving some of the issues with my bike. if you guys have identified any other issue and successfully resolved it, kindly do share with all of us.
    Regards.
  2. #161
    kamranhakro1's Avatar
    Sep 2014
    59
    5 Post(s)
    Quote Originally Posted by rizwan4340 View Post
    If you are not in hurry to buy a bike theb wait for Yamaha to launch new bike or take a Risk of 150. But be sure you are getting fresh piece.
    How to ascertain it is a fresh piece? does the bike mentions some where its date of manufacture, and if so, where to look for such date?
    Many thanks.
  3. #162
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    Quote Originally Posted by kamranhakro1 View Post
    Many thanks.
    May be throught their chassis no. They will be in any order. Ask any Pak wheeler to share his bikes chasis no and then check the dealer. Whats is chassis no of dealers bike
    It is Easy to hate But Love is More Powerful...
  4. #163
    yonaib's Avatar
    Jul 2014
    37
    I want to change my front stock tyre need your recomendation ? Can i make the front tyre to 17 or 16 inch what will be the difference ???
    I already have replaced the back tyre to 18 90 100
    Sent from my iPhone 6+ using PW Forums
  5. #164
    tariq_mirza's Avatar
    Nov 2014
    Default flying taapa issue
    mera 1 tappa ketchry road dg khan mn gir gya
    aur 1200 k 2no taapay mily..shop wala 1 taapa nh dy rha tha
    aur phr mera wahi taapa taunsa bairaaj jaty hoye gir gya tha
    phr me suzuki ki dealer shop pe gya...wo 1 taapa dy rhe thy>..lakin rs.800 ka
    right side wala
  6. #165
    ayubi78's Avatar
    Aug 2009
    69
    nicely done artical on gs150 upgrade.
    platinium spark plugs excellent idea. iridium tipped splugs would have been an ultimate luxury !
    used on a honda vtr250. what a difference !
    nasa liquid grease, good advice, i forced teflon grease mixed in oil into brake and clutch cable,
    works like magic.
    always good to work on own's bike, than let the lpcal screwdrivers screw it up ?
    safe, satisfying and saves money too.
    aye
  7. #166
    abdulrehman1115's Avatar
    Feb 2015
    18
    Brother from where do you bought the smaller spoket plz help me
  8. #167
    Feb 2015
    18
    Friend Karachi me em coil honda deluxe ka Kaha se milly ga or kitny ka kindly tell the totall price of every thing of coil
  9. #168
    Muzi66972's Avatar
    Apr 2012
    187
    4 Post(s)
    Brother from where did you get the windshield for it and for how much?
  10. #169
    smartdevil_striker's Avatar
    Dec 2006
    30
    3,359
    8
    109 Post(s)
    2 Thread(s)
    NGK G-Power Platinum Spark Plug available with me for GS150.
    Platinum&Iridium Plugs,Performance 8MM Wires,Automotive Bulbs and Bosch Horns for sale Contact: 0333-3035482
  11. #170
    zedsharif's Avatar
    May 2015
    33
    21
    Quote Originally Posted by touqeer_khan View Post
    Hi guys,
    I was thinking to buy a new GS-150, but after going through this thread I feel i have to re-think on my decision. Please guide me if your claim/faults are removed by company or not.
    Any suggestion on buying Suzuki 150 is welcome.
    Regards,
    Touqeer
    This has been a very informative thread. It further fortified my decision to buy the bike 😊
    Sent from my iPad using PW Forums
  12. #171
    12gauge's Avatar
    Oct 2013
    176
    68 Post(s)
    3 Thread(s)
    Improving the Performance of you Suzuki GS-150 - Pic 1 zpsslel29pi
    This is some crazy $hit. Isn't it?
  13. #172
    muhammadamjad81's Avatar
    Aug 2012
    9
    nice bike bro i wana buy these boxes for my bike gs 150 where can i buy these ?????????????
  14. #173
    yonaib's Avatar
    Jul 2014
    37
    Salam i have change the stock tire of my gs-150 to 18/100-90 but the wheel base or the rim is the orignal one ,the problem with the bike it vibrates and feel a little bubling my mechanic recomend me to change the rim to 315 size can you guyes suggest me the proper answer with explainations thanks
  15. #174
    iffinca's Avatar
    May 2012
    37
    35
    Normally there should'nt be any bubbling, people are using stock rim with 90/90 or 100/90 tyre, deluxe rim or bigger rim is used for better road grip which helps in leaning on turns .... I think you should check that tyre is properly installed or check the condition of drum rubbers.....
  16. #175
    yonaib's Avatar
    Jul 2014
    37
    Suggest ngk plug for gs 150
  17. #176
    mbilal009's Avatar
    Jan 2013
    can u please let me know the front glass sheet protector availibility in pakistan ??? how much it cost and from where i can buy??? can it be used for other bikes
  18. #177
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    Quote Originally Posted by yonaib View Post
    CR 8E
    CR 9E
    ~ Be a responsible citizen and always drive safely ~
  19. #178
    tucknoloji's Avatar
    Jan 2010
    35
    572
    22 Post(s)
    2 Thread(s)
    Quote Originally Posted by aantherax View Post
    CR 8E
    CR 9E
    CR8EGP
    Sent from my HUAWEI G610-U20 using Tapatalk
  20. #179
    hammadashraf96's Avatar
    May 2016
    8
    Default Suzuki GS-150
    @12gauge
    I bought a GS-150 '11 a week ago, and had the same problem with the ignition coil, but i can't find the Honda Deluxe's ignition coil (DENSO) here in Karachi. Can you give the location guide or contact number of the person from whom i can buy it. Be it of Islamabad, i'll ask my cousin to buy it for me.
  21. #180
    Newbie Follow
    rizmajoka's Avatar
    Oct 2016
    dear from where did you get the side and rear boxes? i want to buy the same if you can guide me. thnks
