Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Like Tree2Likes
Thread: Experimenting a ring shaped electrode spark plug in my Suzuki Sprinter.
    abdulrehmanrauf's Avatar
    Oct 2009
    33
    770
    31 Post(s)
    Question Experimenting a ring shaped electrode spark plug in my Suzuki Sprinter.
    Today I experimented with a ring shaped electrode spark plug in my Suzuki Sprinter. It is actually not a company made, I just converted a standard plug into this by cutting the normal angular electrode.
    Experimenting a ring shaped electrode spark plug in my Suzuki Sprinter -1385165
    I know this has already been discussed somewhere on Pakwheels but I am not getting the link now. I searched a lot. So if anyone know the link of that thread then please share it here.
    Outcome:
    The overall result is very good. Pick though not marginally increased but gets little smoother. Bike has become more responsive now. Ride has become much much lighter and is adding more pleasure.
    Cons:
    As I mentioned the pick has become smoother. But I do like to mention that if I go little hard on the accelerator, want to accelerate little harder in 2nd or 3rd gear then bike is showing the 'Ghutun'. Thori ghut tee hai bike before it generate the shoot. This Ghutun is not very prominent (but exists) in the 4th gear.
    To further clarify, I have not changed the mixture setting, using he same mixture which I was using with the standard spark plug.
    Any consequences?
    - Will there be any negative effect on the bike, like engine heating issue or the spark plug coil.
    - Fuel consumption will increase, decrease or remain same?
    abu-al-hawl's Avatar
    Mar 2014
    7
    a plug is meant to ignite the fuel + air mixture and it has to be in sequential manner, the job you have done on a plug is just resulting distorting order of spark, this will heat your bike with no pickup. that ring shaped electrode plug has it electrode around it where as you have cut the electrode!
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    Wink
    baz dafa experiments bhari par jatay hain
    Oct 2009
    33
    770
    31 Post(s)
    I reverted to the standard plug.
    Reason...acceleration was not stable...it was quick, it was light but not stable so I reverted it back.
    Oct 2009
    33
    770
    31 Post(s)
    Yes sir
    Wese before this experiment I searched a lot on the net and then proceeded with this.
    Quote Originally Posted by JUNOON007 View Post
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    Quote Originally Posted by abdulrehmanrauf View Post
    Yes sir Wese before this experiment I searched a lot on the net and then proceeded with this.
    best of luck. bro for your experiment
    mtmoghul's Avatar
    Apr 2009
    609
    7 Post(s)
    3 Thread(s)
    Hmmmm I think Its not good to do these types of experiments
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    is it same as side gaping ?
    i also noted some improvements when i side gaped a plug that was faragh according to desi mechanics. i have it in my tool box just in case of any emergence i need it..
    dr3vil's Avatar
    May 2009
    11,928
    11
    201 Post(s)
    7 Thread(s)
    get a ngk iridium plug and a spacer ring
    install that
    then see the diff
    Hanjiii Kaa Storeey Eehh !
    mansoor_qadir's Avatar
    Sep 2012
    Attock
    1,476
    11 Post(s)
    Quote Originally Posted by ekdrifter View Post
    install that
    then see the diff
    Cost of ngk iridium?
    <..If everything seems under control, U r not going fast enough..>
    Oct 2009
    33
    770
    31 Post(s)
    install that
    then see the diff
    Bro, I did try to find but not able to get one for bikes. Anyone here knows from where I can get in Karachi?
    Quote Originally Posted by asjdsm View Post
    Bro, so why are you not using but keeping it in tool box even as you mentioned it improves your ride? Also can you please provide some detailed observations what improvement you got?
  12. #12
    dr3vil's Avatar
    May 2009
    11,928
    11
    201 Post(s)
    7 Thread(s)
    Quote Originally Posted by mansoor_qadir View Post
    700 to 900 per plug
    for bikes its hard to find u need to modify car plugs installing spacer rings in it
    trust me i ran a denso Vk 20 iridum plug on a vespa
  13. #13
    Sep 2012
    Attock
    1,476
    11 Post(s)
    700 to 900 per plug
    Vespa must've shocked others with its performance...
  14. #14
    dr3vil's Avatar
    May 2009
    11,928
    11
    201 Post(s)
    7 Thread(s)
    to be honest
    it was scary
    but guys on choands were shocked
    how a 78 vespa is passing them even though its not even 4 stroke and looks all old and rat rod style
  15. #15
    Sep 2012
    Attock
    1,476
    11 Post(s)
    to be honest
    it was scary
    Hahahahaha......chalaak vespa..
  16. #16
    dr3vil's Avatar
    May 2009
    11,928
    11
    201 Post(s)
    7 Thread(s)
    fyi that vespa is dead now
    RIP PRC 6181 it was junk so sold it for 4500rs engine not working nothing working
  17. #17
    Sep 2012
    Attock
    1,476
    11 Post(s)
    Just Rs4500.....so sad......!!!!
  18. #18
    JustFarooq's Avatar
    Apr 2006
    Faisalabad
    33
    1,037
    29 Post(s)
    u got good amount our sells for 5k in running condition
    ALLAH U MMA SALLE ALAA MUHAMMADIN WA BAARIQ WASALLAM
  19. #19
    Sep 2012
    Attock
    1,476
    11 Post(s)
    Quote Originally Posted by JustFarooq View Post
    Hahaha
  20. #20
    dr3vil's Avatar
    May 2009
    11,928
    11
    201 Post(s)
    7 Thread(s)
    yes it went good as most of stuff on that was original but not working
    engine was dead as 2 years before rain water flooded alomost all areas of peshawar and engine as submerged for more then 3 hours
    our neighbour have one same model but in very good nick
    he is getting 7k offer but not selling
    its in great condition well maintaned
