Results 1 to 18 of 18
Like Tree8Likes
  • 1 Post By abdulrehmanrauf
  • 1 Post By amjad635
  • 2 Post By amjad635
  • 3 Post By abdulrehmanrauf
Thread: A quick way to clear a choking carburetor (without opening) of Suzuki Sprinter
    abdulrehmanrauf's Avatar
    Oct 2009
    33
    771
    31 Post(s)
    Lightbulb A quick way to clear a choking carburetor (without opening) of Suzuki Sprinter
    A month before, the carburetor of my Sprinter were started choking (due to impurities in Petrol tank). Symptoms were like bike having suffocation on acceleration. [Just to clarify the carburetor is in healthy condition and it is not badly choked but slightly).
    I consulted my mechanic and he agreed to me that carburetor was choking. I was like do we need to open the carburetor. He told me No. There is a quick way to do that.
    He just turned the fuel knob to off position and took the air pipe (the fat one just above the mixture screw) as shown below.
    A quick way to clear a choking carburetor without opening of Suzuki Sprinter -1398456
    Using the gun he pumped air with pressure, in result petrol came out of the air filter box and some amount of petrol went into the valve area in the head. Waited till the petrol stop coming out of the filter box. At this moment bike was in over state. It took 5 - 6 kicks before it started and then we turned the fuel knob to on position. That's All.
    I was in disbelieve at that moment. Later on I was happy. It did the work. Its a month now and no choking issue yet, very smooth ride.
    I again asked if there is any damage done this way, mechanic said no it is completely safe.
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    safe kasy agar kachara head main chala gaya petrol k sath to kia ho ga
    umer_pervaiz1's Avatar
    Oct 2013
    29
    37
    Was air filter cover/box open?
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    i agree with Junoon same concern from my side as you yourself told
    impurities went into the valve so how is it safe the right or proper
    way would have been he should have removed the carburetor from the bike
    than he should have used air gun. Honda mechanic whom i go for tuning of bike
    he also uses air gun to clean carburetor he does not remove any jets but he uses
    air gun to clean them and carburetor and obviously he removes carb from bike
    Oct 2013
    29
    37
    Why not loose carb screw to remove petrol & impurities init...
    Oct 2009
    33
    771
    31 Post(s)
    Nope. It was not opened.
    Quote Originally Posted by umer_pervaiz1 View Post
    Oct 2009
    33
    771
    31 Post(s)
    I did try this but it didn't solve the problem.
    Oct 2009
    33
    771
    31 Post(s)
    I also agree that the ultimate solution is to open the carb and do the cleaning with the gun.
    In my case it was not that serious. It was slightly choked (as I have mentioned already), fuel tank is clean (no rust), it was impurities we are used to nowadays due to our bad quality petrol.
    And it is unfortunate that our bikes' head/cylinder have to bear all this. Head/cylinder are burning these impurities everyday. The only thing in this case this time carburetor got choked with them.
    Quote Originally Posted by amjad635 View Post
    Quote Originally Posted by JUNOON007 View Post
    Oct 2009
    33
    771
    31 Post(s)
    Or I should start using Petrol filter from now on. Is it worthy?
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    Quote Originally Posted by abdulrehmanrauf View Post
    I also agree that the ultimate solution is to open the carb and do the cleaning with the gun.In my case it was not that serious. It was slightly choked (as I have mentioned already), fuel tank is clean (no rust), it was impurities we are used to nowadays due to our bad quality petrol. And it is unfortunate that our bikes' head/cylinder have to bear all this. Head/cylinder are burning these impurities everyday. The only thing in this case this time carburetor got choked with them.
    kia bike k sath oil filter nahin laga hua
    dongiovanni's Avatar
    Mar 2013
    26
    281
    5 Post(s)
    I used a petrol filter in my sprinter. As a result the carb never got choked even after 90000+ kms, so it was never opened till the day I sold the bike.
  12. #12
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    i can't disagree with you reply yeah there must have not been too much impurities in carburetor
    which went into valve or chamber while cleaning but still the proper way was to remove carb
    intentially throwing impurities into chamber is not good
    fuel filter as for as i know fuel filter is present in all suzuki motorcycles
    which is in between patrol pipe which is connected with carburetor
  13. #13
    Oct 2009
    33
    771
    31 Post(s)
    You meant to say Petrol filter , right? No dear I am not using it currently.
  14. #14
    Oct 2009
    33
    771
    31 Post(s)
    OK dear I got your point.
    And no to Petrol filter, the model I have is 2008 which comes without the fuel filter (unlike we see in Junoon). It is an older model fuel knob which has only the small katori though it has that net (bareek jaali) in the tank. You may see below.
    A quick way to clear a choking carburetor without opening of Suzuki Sprinter -1398520
  15. #15
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    oh well than why not installing fuel filter i recommend install it
    you can easily purchase fuel filter which is present in latest model of sprinters as raider
  16. #16
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    yeah bro fuel filter. must use fuel filter it is necessary for a bike
  17. #17
    Oct 2009
    33
    771
    31 Post(s)
    Thanks Amjad and Junoon bro. I will fit it today
  18. #18
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    alag say bhi fuel filter lag jata hay aur ap genuine kam bhi kar saktay ho new sprinter ki fuel coc.k lagwa lo us k sath fuel filter laga hua ho ga
