Results 1 to 17 of 17
Like Tree5Likes
  • 2 Post By signode
  • 1 Post By JUNOON007
  • 1 Post By zeshanaslam
  • 1 Post By abdulrehmanrauf
Thread: A useful tip for Suzuki Sprinter/Raidor
    signode's Avatar
    Nov 2012
    99
    5 Post(s)
    Default A useful tip for Suzuki Sprinter/Raidor
    Dear members;
    I have Suzuki sprinter 110 which i bought in 2009. Never time it happened that i dont take care of his on time oil change i.e. i changed the oil just after 1000km and oil filter after 3000-4000km as described in manual. I used Shell oil. but despite of all, the ring piston of engine worn out within 50000kms. I talked to my mechanic that why it happened while a great care. He told that manual says that when you change the filter then pour 1-litter oil otherwise pour 700ml. But when we pour 700ml oil (no filter change) the dirty oil in filter related area (we assume 300ml oil) mixes with 700ml fresh oil and make it dirty. So he recommended that whenever you change the oil, change complete and pour 1 litter and also change the filter with local one. never pour wit only 700ml.
    He recommended when my engine is end . I want that other member should follow this instruction and save their engine.
    jadoon1992_vxlimited's Avatar
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    once someone told this for my gs to pour 1200 ml oil at every oil change but i never got the logic behind that. may be some experienced members can help
    people need to grow up sometimes and act MATURE !
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    yah great share and it really healpful for suzuki owners
    zeshanaslam's Avatar
    Oct 2010
    Faisalabad
    113
    2 Post(s)
    I have two 2 each of Air Filter + Oil Filter. Each time i replace one Oil Filter and wash 2nd and keep. And every time i put about 800ml Oil in my bike. Or filter main oil dal kar usko fix karta hon. 800ml se engine oil level bilkul pur ho jata hai. that's it...
    abdulrehmanrauf's Avatar
    Oct 2009
    33
    771
    31 Post(s)
    1000ml is a extra quantity. The guage is the best tool. 800ml (with oil filter change/emptied) otherwise 700ml.
    dongiovanni's Avatar
    Mar 2013
    26
    281
    5 Post(s)
    I had a Sprinter 2006 model. I changed the oil at 1500 kms and changed the Filter on every third oil change and always used to put 700 ml oil in it even after filter replacement. Did 95000 kms on it and sold it to a friend. In that interval only the clutch plates got worn out and were replaced.
    Always check the gauge no matter how much oil you put in it. Just trust the gauge.
    mtmoghul's Avatar
    Apr 2009
    609
    7 Post(s)
    3 Thread(s)
    700 ml when only change oil.
    1000ml when oil filter is also changed.
    (Oil filter is changed approx 4000km)
    This is told me by a Suzuki Mechanic.
    Oct 2009
    33
    771
    31 Post(s)
    I just agree with you bro.
    We have the guage which is the best to tell us the quantity required and it requires 700ml. If we are putting extra 300ml and it exceeds the level indicator on guage then what is the purpose of providing guage. That's the simplest question I have in my mind.
    Even if we are replacing the filter then in this case 300ml is not required. 300ml is not a quantity which can be fit in the oil filter and its compartment.
    We might need to trust the company who made this engine and not the mechanic.
    I have also heard that over pouring the oil will cause early ring burn out / wear out, seal leakage because of the pressure in engine. If you pour extra (eating extra space) then where would the pressure in engine go.
    Quote Originally Posted by dongiovanni View Post
    Zeeshan206's Avatar
    May 2009
    38
    1,779
    27 Post(s)
    10 Thread(s)
    very useful thanks
    <<<***ALHAMDULILLAH***>>>Yah ALLAH tera Shukar
    signode's Avatar
    Nov 2012
    99
    5 Post(s)
    But it is written in its manual that when you change the oil filter then pour 1litter oil otherwise 700ml.
    Mar 2013
    26
    281
    5 Post(s)
    @abdulrehmanrauf That is correct. if you overfill the oil, it might get into the cylinder or increase the oil pressure in the sump and your engine will get worn out faster than usual. Just pour 700 ml of oil and check the gauge. It should be at the recommended level.
  12. #12
    Oct 2009
    33
    771
    31 Post(s)
    Very strange. Bro can you upload a scanned copy of manual. I dont have as I got a second hand. Thanks.
    But one thing is for sure, I always pour either 700 or 800 and not more than this in any case and then checked the level on guage.
    Quote Originally Posted by signode View Post
  13. #13
    Oct 2009
    33
    771
    31 Post(s)
    Bro, can you upload a scanned copy of the manual.
    Quote Originally Posted by abdulrehmanrauf View Post
  14. #14
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    27
    2,488
    59 Post(s)
    Guys guys guys..Its completely normal to pour more oil when replacing filter..
    In cars we change oil filter with oil change so we are quoted an amount like 3L or 4L with filter change.
    When you are changing oil keeping the filter intact there is sill oil left in the filter.That is why you have to pour in 700ml instead of 1L to compensate for the oil already inside filter..
    With filter removal you need to pour in complete 1L amount
    agar suzuki manul say pour in 1L oil then pour in 1L oil period..
    Oil filter kar rubber seal pay halka say oil laga kay install karain(dont pour oil in new filter).Phir oil cap main dalain
    @abdulrehman lala sahi keh rahay hain aap.Masla yeh hai oil/filter change kar kay agar aap 800ml qualtity daltay hai forna nai pata chalta..2-3 min engine start kar kay 8-9 min kay waqfay baad oil level chk karain..It should be lower than expected..
    The one thing that unites all human beings, regardless of age, gender, religion, economic status, is that, deep down inside, we all believe that we are above-average drivers.
  15. #15
    tucknoloji's Avatar
    Jan 2010
    36
    572
    22 Post(s)
    2 Thread(s)
    Default those who want to get rid of the hard brick seat of sprinter
    guys... if you wan tto get rid of hard brick seat of sprinter.... simply get Raider Seat and it is bolt on... no alteration is required...
    buy it and get it either from Suzuki showroom or from Bilal Gunj if you are living in Lahore...
    Raider seat is much much better than old sprinter seat
  16. #16
    umarxe's Avatar
    Jul 2013
    422
    11 Post(s)
    Here is mine.
    I have Suzuki Sprinter 2007 (standard, non eco). I Always used to change oil (0.7 liter) on every 1000 KM and oil filter on every 3rd oil change which is every 3000 KM (1 liter) as suggested by Suzuki Company. Everything is smooth, and except regular oil change and tuning etc I JUST CHANGED CHAIN GRARI SET ONCE and JUST SILAAI BUSH ONCE and my bike has done 60,000 KM to date.
    Most of the times I use suzuki engine oil which I get from suzuki workshop or I use caltex oil. I used Total and Shell oil just 3,4 times.
    I am agreed with @abdulrehmanrauf
    So sprinter got a strong and durable engine which don't worn not easily that's why its the most hot choice for ching chi. From where you are used to purchase oil? Market me 2 number oil bhi tu bohat hai. That's why I have started to purchase only from Suzuki from last two years. When I go their workshop for regular tuning and oil filter change, I purchase two bottles of 0.7 and change 2 oils at home myself and then 3rd one again from their workshop with 1 liter oil.
  17. #17
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    I would like to add some thing sprinter manual say that you should fill 1l and gauge have limit of 0.7ml the thing everybody forget is temperature when oil become hot it loss it viscosity a lil and if we see suzuki highly recommend to warm up the bike before use to that oil become a lil thin and a thing that I found in my junoon manual was that the user should warm up his bike on full throttle with chock before oil changed that is due to that fact that the oil will become thin and every drop of old dirty oil will be come out from engine
