Page 4 of 4 FirstFirst ... 234
Results 61 to 73 of 73
Like Tree2Likes
Thread: Suzuki GS150 misfiring issue
    fanno__'s Avatar
    Mar 2006
    26
    29
    3 Post(s)
    Default [RESOLVED] Suzuki GS150 misfiring issue
    I have been having a problem with my GS150 since the past few weeks. It does alot of missing in the cold state and the idle RPM are never stable. It tends to turn off if i try to accelerate modestly in the cold state. The overall performance gets better when it is rode around 4-5 km's and the engine is up to a high temperature though. But those first few Km's are nearly impossible to bear.
    After alot of reading at PW forums, i have tried the following solutions:
    * Got it tuned from Suzuki Asif autos (A grade shop) at McLeod road Lahore
    * changed the oil (SGO) and air filter
    * changed the spark plug to NGK platinum (G power)
    * change the ignition coil to Nippon denso bottle ignition coil
    (Toyota Mark-||'s)
    * tried to set the air fuel mixture myself a few times
    * measured the battery voltage before and after starting the bike (they were adequate)
    but still no use! none of these seem to solve the problem. Does anyone have any idea what might be wrong here?
  2. #61
    sleepyhead's Avatar
    Jun 2014
    Faisalabad
    147
    2 Post(s)
    Quote Originally Posted by Haji__John View Post
    Sir @basic aap ne manual printed values hi use ki thi bike soundless ha na?
    Haji saab, I tried using the printed values for intake and exhaust at three different occasions and couldn't get away with either o the ticking sound or startup problems.
    I then looked up optimal values and they need to be same for both valves. I also consulted expert opinion such as Dan's Motorcycle Valve Adjustment
    If you have a hard/physical copy of the book, you will see several typing mistakes. Heck, for intake valve, the "IN" is written as "1N".
  3. #62
    basic's Avatar
    Aug 2005
    Faisalabad
    50
    1,241
    13
    98 Post(s)
    3 Thread(s)
    Any time, I live in Madina Town area, canal is near my area too.
    My cell is 0321-9660230.
    Quote Originally Posted by sleepyhead View Post
    Sure basic bhai. Whenever you plan to visit Canal Road (either east or west side) or Gutwala, let me know please
    MADE IN WAZIRABAD.............................RUNNING IN FAISALABAD..........
  4. #63
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    Here's one more interesting find for dear friends @hami, @basic and to other folks who will/are reading the official service manual:
    DO NOT USE COMPANY PROVIDED VALVE CLEARANCE SETTINGS.
    I believe they are either mistyped or are for some other model.
    Here's the explanation.
    Suzuki GS150 misfiring issue -1540545
    Dear app key bike kay sath koi problem hay mainay setting change kernay say pehlay acchee tarah measure key thee intake ka to mujhay pata nahin per Ex wala valve 100% 0.13mm per tha aur abb bhee oosey setting per bike chal rahee hay siwiay normal engine noises kay aur koi awaz na hay
  5. #64
    sleepyhead's Avatar
    Jun 2014
    Faisalabad
    147
    2 Post(s)
    Quote Originally Posted by hamikhan View Post
    How did you check the valve clearance? Did you set it on the TDC of Compression Stroke before you measure it?
  6. #65
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    yes dear i did it on TDC
  7. #66
    sleepyhead's Avatar
    Jun 2014
    Faisalabad
    147
    2 Post(s)
    There are two TDCs in off state. Compression and exhaust. Which one you did it on?
    Did you get a reading on intake valve as well?
  8. #67
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    My dear super sleepyhead no there are not two TDC except one rotate the magnet & align this ( l ) kind of line who is embossed on magnet to arrow mark which is on engine piece here you can see intake & exhaust valves rocker arms are get loosed if not then rotate the magnet again & align the marks again here you will get perfect setting state on this setting you can adjust valves perfectly
  9. #68
    sleepyhead's Avatar
    Jun 2014
    Faisalabad
    147
    2 Post(s)
    No there are two TDCs (Top Dead Centers) in off state. Compression TDC happens right after intake valve closes.
    There's one more way to check that. If you use a screwdriver and put it in the plug hole, you can feel the piston in the upright position. If that happens along with intake valve closure (it will rise), then it is "COMPRESSION TDC". Otherwise, it is not.
    Suzuki GS150 misfiring issue -1542067Suzuki GS150 misfiring issue -1542068
  10. #69
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    Bhai mujhay lagta hay app ka kam lamba hota ja raha hay wo bhee khomkhoa main agar main physically faisalabad main hota to appko samjhata verna valves set kernay ka perfect procedure wohi hay jo mainay appko ooper post main bataya hay
  11. #70
    sleepyhead's Avatar
    Jun 2014
    Faisalabad
    147
    2 Post(s)
    I know that already bro I was just correcting you.
  12. #71
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    Super sleepy bro app nay apni bike kay Intake & Exhaust valves ko: 0.08 mm setting per set kernay kay baad kya kya faiday hasil keay hain?
  13. 09-05-2015, 05:05 PM
    Newbie
  14. #72
    Newbie Follow
    hamid_sharar's Avatar
    May 2015
    hi... this is a representative of Suzuki Asif Autos (as mentioned in your original post). Unfortunately, we do not recall installing a toyota ignition coil in a bike. we checked our job cards and could not retrieve any data referring to your issue. we do not even recommend any automotive parts other than Suzuki Genuine parts specially when the parts are easily available on all Suzuki dealerships. would it be possible for you to revisit our workshop so we can perform a complete checkup of your motorcycle and try to resolve the issue to the best of your satisfaction.
    thank you.
  15. #73
    hammadashraf96's Avatar
    May 2016
    8
    How much did the ignition coil cost you ?
