Results 1 to 17 of 17
Like Tree8Likes
  • 1 Post By ammarzahid
  • 1 Post By angel82
  • 1 Post By vickytulla
  • 1 Post By angel82
  • 1 Post By r3b3l1
  • 1 Post By jigzKorner
  • 1 Post By hamikhan
Thread: Availability of bigger GS150 sprockets
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    Default Availability of bigger GS150 sprockets
    Hi guys,
    I want to know if its possible to source a larger front sprocket or smaller front sprocket for a GS150. @vickytulla @angel82 please help!
    angel82's Avatar
    Nov 2005
    34
    1,003
    6
    284 Post(s)
    6 Thread(s)
    Why do you need it.
    Sent from my HUAWEI G7-TL00 using Tapatalk
    https://www.facebook.com/groups/SoberRiders/
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    Quote Originally Posted by angel82 View Post
    Why do you need it.
    Need more low end
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    bhai mushkil hai its an uncommon thing banwani peray shyid apko.. GS150 ki alterations kerty hain wo bata sakty hain ... B.O.B group men wo jino nay GS150 ko strip down ker k cafeRacers or bobbers banayee hui hain might be they have some knowledge
    Quote Originally Posted by ammarzahid View Post
    Need more low end
    mohsinwahhab's Avatar
    Jul 2013
    26
    1,133
    19 Post(s)
    Yes It is available in karachi but I don't know the exact place I think in ranchor lane.
    noblerider's Avatar
    Apr 2014
    665
    14 Post(s)
    2 Thread(s)
    Can anyone tell what is this low end in asan bhasha???
    I dont overtake............. I simply takeover
    angel82's Avatar
    Nov 2005
    34
    1,003
    6
    284 Post(s)
    6 Thread(s)
    Quote Originally Posted by noblerider View Post
    Google Low end torque and you can get the answer in Asaan Tareen Bhasha.
    arsi_mast's Avatar
    Jan 2009
    25
    228
    3 Post(s)
    You should check sprockets at auto race or contact safeer mechanic... He was working at suzuki mareer hassan murree road....
    arsi_mast's Avatar
    Jan 2009
    25
    228
    3 Post(s)
    For larger front sprocket I'll suggest you gs500 front sprocket it has 17 tooth whereas gs150 has 15 tooth you might see acceleration lag.. But top speed will be awesome... I'm pretty much sure gs500 sprocket will fit in Gs150 you can buy brand new gs500 parts from suzuki they use to sell its parts...
    12gauge's Avatar
    Oct 2013
    176
    68 Post(s)
    3 Thread(s)
    Quote Originally Posted by vickytulla View Post
    Bro the bobbers which you are referring to are all using stock sprockets. no disrespect intended but the modifications in the said bobbers and cafe racers are only limited to the obvious and not the technical.
    Regards.
    12gauge's Avatar
    Oct 2013
    176
    68 Post(s)
    3 Thread(s)
    Need more low end
    you can always try searching for a smaller front sprocket. simply put (no pun intended), 1 tooth on the front sprocket is roughly equal to 2 teeth on the rear sprocket. if you are unable to find a larger rear sprocket, you can look for smaller front sprocket instead.
    Quote Originally Posted by arsi_mast View Post
    i am sorry bro, Suzuki GS-150's front sprocket bay cannot accommodate any sprocket larger than 14 teeth. I could be wrong but I remember stock sprockets as F14/R43. like I said, I could be wrong.
    Regards.
  12. #12
    arsi_mast's Avatar
    Jan 2009
    25
    228
    3 Post(s)
    Quote Originally Posted by 12gauge View Post
    Regards.
    Nope bro i think i have counted the front sprocket, it has 15 teeth.
    From where did you ordered the rear sprockets and how much it costed you???
  13. #13
    12gauge's Avatar
    Oct 2013
    176
    68 Post(s)
    3 Thread(s)
    like I said, I could be wrong. its been a while I have been using 14/45 combination therefore my memory is a little off. anyways, I am using JT sprocket set with stock chain.
    Regards.
  14. #14
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    oh.... @ammarzahid you always have butt sab. in any case...
    Regards.
  15. #15
    r3b3l1's Avatar
    Sep 2016
    Lala musa
    Tariq sb,
    Sir please i want to contact you...
    Is it possible???
  16. #16
    jigzKorner's Avatar
    Nov 2012
    Bahawalpur
    24
    161
    5
    23 Post(s)
    i have made custom sprockets
    use cgz external teeth dial and inner gs sprocket dial
    and send it to krachi to hammad.
    rear i have used gto kawasaki"s 39teeth and front cg's 17
    so 17 39 combinations
    Sent from my XT1254 using PW Forums mobile app
    http://www.pakwheels.com/forums/biking/241419-bahawalpur-khunjerab-pass-5300km-bike
  17. #17
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    You can use sprinter rear sprocket for your purpose
