Results 1 to 6 of 6
Thread: Suggestion Required for Front Disk Brakes
    syber's Avatar
    Feb 2008
    68
    Question Suggestion Required for Front Disk Brakes
    I want suggestions from experienced people about Front Disk Brake in Suzuki Gs-150
    1. which disk brake is adjustable /suitable for Gs-150 (2014-2015 models)
    2. what is your experience about disk brake if you have it on your gs-150
    3. where to buy disk brake
    4. what is approximate cost for it
    Regards
    Haroon Kamran
    Keep Calm and Twist the Throttle
    scarfase's Avatar
    Dec 2013
    139
    6 Post(s)
    complete setup cost Rs. 20,000 here in Karachi with alloys and result is very good.
    mohsinwahhab's Avatar
    Jul 2013
    26
    1,134
    19 Post(s)
    If you install only disk brake without alloy and fork bottle modification it will cost you 7-8 thousand, 6-7 used disc brake setup 1 k fitting
    syber's Avatar
    Feb 2008
    68
    thank you for the informatio
    UsmanAhmed123's Avatar
    Nov 2013
    Rawalpindi
    32
    5
    Default Need help in RWP
    Any idea where to buy alloys and disc break in Rawalpindi? Or you may suggest some dealer in Lahore, contact details would be welcomed. By the way I have GS 150 2013
    Synchrony's Avatar
    Oct 2011
    97
    5 Post(s)
    Quote Originally Posted by scarfase View Post
    That sounds a bit too steep for a price for the complete pair. I remember I once (2012) did the whole pair (Honda alloys, disc brake, drum brake, sprocket) for 13,000rs for a good friend of mine.
    Rx115 would be a suitable option for the OP. Do not pay more then 8 to 9,000rs for just the disc brake however. Also make sure you get a master cylinder (Brake lever pump) that looks similar in size to the original Rx115's. Reason I say this is because karachi markets are full with small sized incompatible with rx115 master cylinders that have tiny useless pistons in them.
Tags for this Thread
