Results 1 to 4 of 4
Thread: GS headlight reliable solution required.
    kenreaves's Avatar
    Oct 2013
    Hyderabad
    11
    Default GS headlight reliable solution required.
    I've tried a Tri LED in stock GS head light turns out you cant replace dead Leds with new one. So LED experiment is failed. Now i' m lookin' for a reliable solution for GS. I read somewhere we can purchase XANADU. Glass lens and metal reflector separately. I need contact details of the spare parts dealers in Karachi.
    Similar Threads:
    nnabeel's Avatar
    Mar 2006
    37
    400
    I don't know if there any markets for imported car parts just like we have in khi> go there and search for pathans having lights/ switches/relays horns etc for imported and old cars. Ask them for unsealed beams imported ones similar to size of Suzuki high roof head light. they will sell pair n 1700 or 1800 rupess.... get single light and it needs minor adjustment to fit in GS 150. it front is glass and back is steel and make will be koito ...I think
    haseeburahman's Avatar
    May 2012
    99
    I fitted Suzuki Bolan haed light in my GS-150. Added two rectifiers with head light switch for low / high beam and connected with battery. lamp i use was of Diamond brand costing 350 rs. Cost of rectifier is 120 rs each. and some wires.
    Dont connect this bolan head lamp direct without using rectifiers.
    saadullah.b's Avatar
    Nov 2012
    Gujranwala
    31
    33
    Dude, I have installed a projector LED in it and it works perfectly.
    I also have imported a dual headlight that apparently feels good in tests. Have not installed it as yet. Am thinking of doing it this weekend, time permitted of course.
