Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By codenameir
  • 1 Post By Xulfiqar
Thread: How is Hi-octane Fuel not better for a GD 110cc engine ?
    codenameir's Avatar
    Feb 2015
    28
    26
    Question How is Hi-octane Fuel not better for a GD 110cc engine ?
    Hello friends.
    I have heard from a few people that filling tank only with hi octane causes valve leakages or damages insides of the engine or carbeurator.
    How's that even logical or possible?
    Because that fuel is the most clean form of cumbustion. Why would it harm a 110cc's engine.
    My personal experience with both type of fuels.
    Regular = smoother bike , lesser fuel average per litre , lesser acceleration and top speed time increased.
    Hi octane = slight increase in vibration , higher fuel average per litre , faster acceleration and reduced top speed time.
    usman7191's Avatar
    Jul 2015
    28
    399
    5 Post(s)
    I find every thing better while using hi oct in my mahran ..
    Like top speed
    Acceleration
    Milage
    Wail hai, Be namazion k liye ..
    arsi_mast's Avatar
    Jan 2009
    25
    228
    3 Post(s)
    Hi octane is good for any type of engine but mostly people make a 50:50 mixture of hi-octane with regular... Performance engine requires a 100% hi-octane with high octane number...
    RocketScience's Avatar
    Aug 2012
    960
    153 Post(s)
    10 Thread(s)
    No need to put high octane in less cc bike
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3990 Post(s)
    94 Thread(s)
    6
    using higher octane fuel in an engine not designed for it (low compression) will result in thick soot/carbon deposits in the combustion chamber and valves and loss of acceleration/performance because it burns slower.
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by RocketScience View Post
    Cc have nothing to do with fuel type
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    I am using high octane only since day one in my gs 150, I need your suggestion on it my bike has clocked 1540 kms till now
    ~ Be a responsible citizen and always drive safely ~
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    Nothing is gonna happen with your bike engine if you use only hi octane i have used many times only hi octane in my gs 150 has clocked above 22k Alhamdolilah still going so strong
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Hi Octane should not be used in engines with compression ratio of less than 10. My GS500 has compression ratio of 9.0:1, means I should only use regular fuel. Smaller bikes like GD110, GS150, CG125 etc should also use regular fuel.
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    Quote Originally Posted by 7thgear View Post
    If someone keep on using high octane would that damage the engine or what ?
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    ^Obviously..
