friends meri gs 90 se opar nahijati bohta koshish ke hai main ne alloy rim lagayen hain or us k sat mistri ne 125 ka spoket laga deta kaha k is rim k sat yahe set ho ga ab meri gs 90 se opar nahi jati kiya karun help me friends
bhai kis jahil mechanic sey kaam karwaya tha us ko do chamat lagao aur dobara geniune sprocket lagwao bike men
The soo cold mistri increases the sprocket size.........because of which now it not goes more then 90.
to abb kiya karon bhai koi tariqa bata dy
bhai wo jahil mistre to suzuki wala he hai babar name hai rawalpindi main hota hai abb kiya main wapis apni wali spoket laga sakta hun is rimz main?
Brother decrease the sprocket size for example if stock size was 41 then install 39 as a result of it speed increases but if you want acceleration then decrease the size of front.
Sprocket kesi fitting ka hai Suzuki ka a center per ek bolt ka hota hai air ziyda tar bikes mai do (2) but wala hota hai?
kabhi deka nahi dek lon ga wese mujhai bike ke zayada samj nahi hai car chala chala k bore ho gaya to bike par hat dal diya
@hassan1991 bro i didnt know b4 that to gain high acceleration, front sporket size is decreased
This is my personal experience on my 1990 cd70....I have done many experiments on it.......decreasing front sprocket size increase acceleration but decreases speed.But person should be practical like he can't make it larger or smaller more then limit bike will reduces torque rather then gaining.
bro can u tell me in light of ur experience what is the optimum sporket size for front and rear to gain maximum torque and top speed
Keep front sprocket stock decrease rear for example if stock is 41 then install 37......pull out the air filter slightly modify carburettor then sit on your ride and drive
You also have to reduce the chains length
bro how much length of chain should be reduced??
Tashfen bhai appko aik aasan saa tarika batata hoon app apni Gs sameet kisey khai mein jump laga do qisa khatam hahahahahahaha
Boss jitna sprocket small kerain *** chain automatic loose hotee jayee gee don,t mind about my words use your common sense
Bro it depends......
thanks a lot bro
No problem
