Results 1 to 6 of 6
Thread: suzuki 150 air lock
    ibrahimhashmi11's Avatar
    Oct 2012
    29
    152
    7 Post(s)
    Default suzuki 150 air lock
    Solution
    I got my bike washed up. after that there is air lock after every approx 5 kms and i have to open the fuel tank cap again and again to release the air lock after which i can drive again. Kindly tell me how to resolve it
    Hassan1991's Avatar
    Mar 2013
    20
    2,279
    38 Post(s)
    Quote Originally Posted by ibrahimhashmi11 View Post
    First clean fuel tank cap if it still gives problem then clean carburettor.
    The first step towards knowledge is to know that WE are IGNORANT
    zeshanaslam's Avatar
    Oct 2010
    Faisalabad
    113
    2 Post(s)
    Community Votes: 1
    Fuel cap utar kar us main tez hawa (compress air) maro, is se masla hal ho jayega. Agar ye tip kam na karay to phir fuel cap ko sara khol kar achi tarha saaf kar k dobara fit karo.
    Atif_Jawaid's Avatar
    Aug 2012
    129
    I think this iz not the carburetor.....issue if it is save from water
    Their is a pipe in carburetor which lead to behind near where the air filter installed ... around plastic frame of the air filter find the pipe... detached it and cleaned it .. also clean the hole of carburetor with cotton bud
    this may help to resolved the problem INSHA ALLAH
    Oct 2012
    29
    152
    7 Post(s)
    can you tell that where is the carbereatur hole located??
    Oct 2012
    29
    152
    7 Post(s)
    ok guys it was simple air lock. went to a suzuki certified mechanic who solved this problem once in for all. thanks for your comments though. appreciated
