Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By imranbhatti
Thread: Signs of bad clutch plates GS150
    Haji__John's Avatar
    Dec 2011
    Rawalpindi
    25
    293
    5 Post(s)
    Default Signs of bad clutch plates GS150
    Salam guys
    Can any expert tell me what are the indications of bad clutch plates. My mechanic saying that clutch plates of my GS 150 needs to be changed.
    It is 33000 KM driven till now.
    "Imagination is more important than knowledge"
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    During riding if u rev the engine hard without pressing cluthch the engine revs up and ur speed remains the same this is a very obvious indication, other indication might be observed with no jerk on hard shifting etc. Do u have any abnormal feeling in ur ride?
    specially while engaging and disengaging the clutch during shifting ?
    Exploring Machines is my Passion...
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    can you guide what might be the problem when you are in trafic jam and you are in any gear and stopped bike still keeps you pushing untill the engine stalls ? even adjusting the Clutch do not helps and feels like bike is still pushing.. ? is that a bad clutch which keeps on engaging even you have pressed its lever completly ???
    Quote Originally Posted by imranbhatti View Post
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @vickytulla
    That too is the symptom of problematic clutch system, but it can also happen with poor quality clutch plates, friction plates, clutch hubs. If u r experiencing it with Chinese engines then its quality issue but with some time Japanese brands with stock parts are observed to have this issue too which can be sorted out by using proper grade 4t specific lube oil.
    SyedMoazzam's Avatar
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    During low gear 1st and 2nd when i shift up, i feel missing in gears. Also bike seems to pick up throttle a little late.
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    Quote Originally Posted by SyedMoazzam View Post
    That doesn't seems t be issue associated with clutch system, seems to be Carb adjustment or ignition related issue.
