Results 1 to 6 of 6
Thread: Suzuki GS 150 Missing/Stopping on Irregular intervals
    bc003mzy's Avatar
    Aug 2006
    33
    27
    Default Suzuki GS 150 Missing/Stopping on Irregular intervals
    Hi,
    I have GS 150 2012 Model. Since couple of weeks it suddenly start missing and gradually stops. After starting again runs fine but same behavior happens later on. So far i have done following things
    1. Plug checkup
    2. Oil Change
    3. Engine Tuning
    4. Carburetor Cleaning
    5. Petrol Tank Cap
    6. Petrol Quality
    Now mechanic is asking for Clutch Plates and Pressure plates change. Kindly advice if its fine or anything else can be checked. Thanks.
    Regards,
    Muhammad Zahid
    Shafin619's Avatar
    Sep 2012
    21
    2,699
    95 Post(s)
    2 Thread(s)
    Check its current coil maybe bike is not getting proper current from current oil.
    Sent from my SM-J700H using Tapatalk
    4 wheels move the body 2 wheels move the soul
    bc003mzy's Avatar
    Aug 2006
    33
    27
    @Shafin619: Thanks for the advice. I will check. But anything related to clutch/pressure plates ?
    Hassan1991's Avatar
    Mar 2013
    20
    2,260
    37 Post(s)
    Quote Originally Posted by bc003mzy View Post
    There's no connection of missing of a bike with clutch plates.
    The first step towards knowledge is to know that WE are IGNORANT
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    You need to find a better mechanic if your mechanic is blaming clutch plates for missing
    mehals's Avatar
    Feb 2014
    14
    AOA
    brother i have faced same issue last month and believe me you will be surprised when i will tell you the root cause of my bike missing and sudden stop.
    initially i was also focusing on ignition coil and i have replacement it with suzuki genuine NGK ignition coil, and found out that suzuki itself purchasing substandard ignition coil from some local supplier after that i have got honda 125 Deluxe ignition coil for Rs 1450 from makhdum.
    in my case the main culprit was battery terminal connection loose, because i have installed a maintenance free battery its contacts are a bit difficult to manage.
    i suggest you to kindly cross check the both ignition coil contacts and battery contacts and make sure they tightly fitted or replace them if required, my advise to you is don't use it in this condition as you might damage your engine, timing chain or connecting rod might get effected.
    hope this solve your issue.
    take care
