Results 1 to 12 of 12
Thread: GS 150 handle vibration
    ibrahimhashmi11's Avatar
    Oct 2012
    29
    152
    7 Post(s)
    Default GS 150 handle vibration
    Solution
    Salam guys.
    I am facing this problem in my bike that when i drive its handle has a vibration which causes uneasiness and pain on long routes in shoulders. I went to a mechanic who said that its cuz of tyre. so i got it fixed but of no use. Then another mechanic told me that this issue is there in all the 150s after 2012. The company shifted their plant and there is some issue in the frame production which causes this..and he advised me to get it fixed by a denter and it will be costing around 6 k. I am confused what to do..please help
    saboor73's Avatar
    Oct 2013
    10,545
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    Problem with frame of gs is more with alignment of bike I doubt its cause of vibration
    engr.omersharif's Avatar
    Feb 2015
    31
    259
    2 Post(s)
    Quote Originally Posted by ibrahimhashmi11 View Post
    Salam guys.
    Did you try the authorized suzuki service centre? They are usually trained by the company and can take a look.
    Sent from my SM-J700H using PW Forums mobile app
    Oct 2012
    29
    152
    7 Post(s)
    yes..but they couldnt satisfy nor solve it
    Hassan1991's Avatar
    Mar 2013
    20
    2,260
    37 Post(s)
    Check the bearing of front wheel
    Also tightened the "anak" (don't know what this thing is called in english) nuts.
    These causes vibrations which further causes pain in hands
    The first step towards knowledge is to know that WE are IGNORANT
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    Salam guys.
    1st adjust the height of the handle bring it down, by factory it is set very high which cause pain in shoulder while riding ,
    2ndly chk the front tire pressure it should be kept at 26 max, and if u are feeling jerk in handle while passing pot holes u need to visit the suzuki dealer nearby your place and ask them to adjust the handle play. do not ask normal mechanic or honda mechanic to adjust it, as suzuki gs150 handle setting is bit different than other bikes. if possible visit suzuki dealer opposite Aladdin park they got some good mechanic to fix all of the problem.
    Help others so that u can be Helped
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    Community Votes: 1
    Misaligned or sticky front suspension can also cause undue vibration which penetrates to shoulder through arms please have it checked along with front wheel balancing. Tyre It self can be culprit too in some cases.
    Exploring Machines is my Passion...
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by Hassan1991 View Post
    ainak of bike is usually called "triple tree" or "steering header" and in Karachi its called "tee"
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by archon2001 View Post
    this reminds me, a person contacted me on PM and asked the same thing, he discovered that the bearings in the header were completely dry from the factory which was causing really bad clunking.
    btw - does your machine have the weighted handle bars like the first ones had?
    Hassan1991's Avatar
    Mar 2013
    20
    2,260
    37 Post(s)
    Thanks sir
    I searched a lot on internet but never found the it
    hassantahir2's Avatar
    Mar 2016
    Faisalabad
    22
    812
    17 Post(s)
    Thanks sir
    Add one more "stem steering".
    Sent from my D2502 using PW Forums mobile app
    Four wheels move the body
    Two wheels move the soul
  12. #12
    Hassan1991's Avatar
    Mar 2013
    20
    2,260
    37 Post(s)
    Quote Originally Posted by hassantahir2 View Post
    Haha thanks to you too
