Results 1 to 11 of 11
Thread: Suzuki sprinter
    HassanMehmoodHaider's Avatar
    Sep 2012
    21
    64
    Hassan1991's Avatar
    Mar 2013
    20
    2,265
    37 Post(s)
    change the shocks
    The first step towards knowledge is to know that WE are IGNORANT
    Sep 2012
    21
    64
    Kon se laga doun mainy kahin parha tha ke 150 ke lagane se theek ho jata hai ye issue
    Hassan1991's Avatar
    Mar 2013
    20
    2,265
    37 Post(s)
    Quote Originally Posted by HassanMehmoodHaider View Post
    ya issue shuru sa hai?? i don't think sprinter had this issue.You should use original or you can also get aftermarket adjustable shocks
    Sep 2012
    21
    64
    Hassan from the very first day ye issue hai pehly hum 2 bahi travel karty thy stude ke liye tu suspension hard rakhi thi lakin ab main akeela reh faya houn tu soft karny pe tyre lagta hai or hard rakhny pe pain hoti hai back main
    Hassan1991's Avatar
    Mar 2013
    20
    2,265
    37 Post(s)
    ap shock aftermarket laga loo mera hesaab sa fitting aesa hi ho jae gii
    abdulrehmanrauf's Avatar
    Oct 2009
    33
    770
    31 Post(s)
    Which model do you have and what tyre brand/size it has? I have this same issue and I have been able to overcome quite successfully.
    Bara CG-125 bana phirta hai jou Sprinter say derta hai ....
    Sep 2012
    21
    64
    Tyre panther size 2-75. 18
    Sep 2012
    21
    64
    Bhai jo bhi solution hai bata dain mujhy kisi ne lamby shocks ka bhi kaha hai app ka jo solution hai wo bji bata dain.
    Oct 2009
    33
    770
    31 Post(s)
    My mechanic did three things,
    1. Made new holes (as indicated by the red dot below) , lower to the original holes, resulted in mud guard mounted an inch higher.
    Suzuki sprinter -1697377
    2. Secondly, increase the length by half an inch or so of the original jumps. It could be done adding a check nut.
    3. Third is the most common one, adjust the drive chain so that tyre should be nearer to the engine instead of mudguard tale.
    Sep 2012
    21
    64
    Mainy laga diye hain lenghty wale shock absorbers sara masla haal ho gaya hai
