Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By hassantahir2
Thread: Suzuki GS 150 Rear Wheel Design
    engr.omersharif's Avatar
    Feb 2015
    31
    259
    2 Post(s)
    Default Suzuki GS 150 Rear Wheel Design
    AoA,
    I currently have a Honda CG 125 Deluxe. The rear wheel is a bad design and many puncture shops refuse to make it. I think it is added complexity. Does Suzuki GS 150 also suffer from same problem?
    Sent from my SM-J700H using PW Forums mobile app
    hassantahir2's Avatar
    Mar 2016
    Faisalabad
    22
    812
    17 Post(s)
    In Suzuki GS 150 it's almost same as of Honda CD 70. (Almost)
    Sent from my D2502 using PW Forums mobile app
    Four wheels move the body
    Two wheels move the soul
    Feb 2015
    31
    259
    2 Post(s)
    Thanks, that is encouraging.
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,276
    90 Post(s)
    7 Thread(s)
    Deluxe rear sprocket is bolted to the wheel hub, i guess that's why it is complex for puncture shops?
    Sent from my LG-H815 using Tapatalk
    Mar 2016
    Faisalabad
    22
    812
    17 Post(s)
    Quote Originally Posted by gull_s_777 View Post
    If this is the case then they might have problems with CG classic then it also has its sprocket bolted to the Hub.
    Feb 2015
    31
    259
    2 Post(s)
    Yes, that is correct. It is a bit tricky.
    I think I remember you. You are the person who owned a deluxe and switched to GS 150.
    Did you do any modifications to GS 150. Rear tyre, Disk brakes etc.
    Feb 2015
    31
    259
    2 Post(s)
    Aside sprocket being directly attached to the rear wheel. The rear wheel also sits in a slot. And chain cover needs to be removed.
    Feb 2015
    31
    259
    2 Post(s)
    Quote Originally Posted by hassantahir2 View Post
    Hey! I saw your post regarding GS 150 . Apologize for asking again.
    Keep up the good work.
    Mar 2016
    Faisalabad
    22
    812
    17 Post(s)
    Quote Originally Posted by engr.omersharif View Post
    I am also currently owning a Suzuki GS 150 my EX-Ride was a Honda CG 125 Classic...
    No need for apologies.....! ☺
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,276
    90 Post(s)
    7 Thread(s)
    https://www.pakwheels.com/forums/sho....php?p=3882096
    Feb 2015
    31
    259
    2 Post(s)
    Thanks gull sahab I found your thread.
