Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Like Tree5Likes
Thread: 10W-40 or 20W-50(LM) is better for GS?
    bykelover's Avatar
    Sep 2014
    117
    2 Post(s)
    Default 10W-40 or 20W-50(LM) is better for GS?
    Dear all,
    Kingly give your point of view and share your knowledge regarding the LM Motorbike 4T 10W-40 Street (((SYNTHETIC)) and Motorbike 4T 20W-50 Street ((MINERAL))
    Which one is better for SUZUKI GS 150 and why?
    Naveed4speed's Avatar
    Aug 2006
    Sialkot
    26
    6,132
    7
    49 Post(s)
    2 Thread(s)
    10W40 is recomended grade for suzuki GS150.
    and i will aslo recomend you to go for 10W40.
    becasue 10W40 is thin oil with better fuel economy and acceleration as well as performance.
    it make less wear and tear to engine.
    also its semi syntehtic so it has more life then mineral 20w50.
    so all in all i always recomend 10w40 since bike is new.
    FXXB and EJ8 on its way............
    bykelover's Avatar
    Sep 2014
    117
    2 Post(s)
    Thank you for the reply, can u plz also inform me about the interval b/w oil change?? after how many kms should i change this oil ?? my byke is only 10,000 km old...
    Quote Originally Posted by Naveed4speed View Post
    Aug 2006
    Sialkot
    26
    6,132
    7
    49 Post(s)
    2 Thread(s)
    oh you already drove 10000 kms.
    if you drove all on 20w50 then 10w40 is not recommended.
    becasue while 20w50 made enough wear the 10w40 will not work well.
    regarding.
    oil interval it depends on the oil brand.
    the Zic should not be drove more than 1000-1200 kms.
    and the other low priced should be even used at for less interval.
    while Liqui moly is able to work good for atleast 1500-2500 kms (company life is 5000 kms)
    tintin1's Avatar
    Jan 2014
    1,851
    8
    61 Post(s)
    2 Thread(s)
    8
    5
    regarding.
    Did you experience to drive LM oil for 2500 km for Motor bikes?
    I guess its just a craze for bikers to use LM oils. Same like people use “Hi-Octane” in CD70, 125, etc. assuming that its good for Engine without even knowing that motor bike engine doesn’t need Hi-Octane.
    Be Addicted To Help Others.
    tintin1's Avatar
    Jan 2014
    1,851
    8
    61 Post(s)
    2 Thread(s)
    8
    5
    Quote Originally Posted by bykelover View Post
    Dear all,
    Read the manual first to know which oil Suzuki has recommended to use and stick to that oil.
    Using expensive engine oils doesn’t make any significance. PK bikes are old technology engines and they need old grade oils.
    Most commonly recommended oils for bikes are mineral based oils 20w-40, 20w-50 of 4T.
    I literally seen people using ZIC A+ for bikes which is extremely not recommended by OEM. But ignorance has no limits.
    bykelover's Avatar
    Sep 2014
    117
    2 Post(s)
    I have only use it(20w50) twice ,other wise i was strictly using Suzuki's 10w40 oil. So what do to say now? should i go for 10w40 or 20w50???
    regarding.
    Aug 2006
    Sialkot
    26
    6,132
    7
    49 Post(s)
    2 Thread(s)
    hmmm if you used suzuki genuine oil which is (10w40)
    then you can go for 10w40.
    Aug 2006
    Sialkot
    26
    6,132
    7
    49 Post(s)
    2 Thread(s)
    bro if you used suzuki genuin oil more time than 20w50 then its ok you can go with 10w40.
    and @tintin1. brother i am using Liqui moly 10w40 in my ybr 125 since first oil change and its serving me well and i have driven almost 12000 kms.
    and i have taken the interval from 3000 kms to 2000 but best result last till max 2500.
    shoaib992's Avatar
    Apr 2013
    24
    71
    2 Post(s)
    Go for kendall 10w40 oil with liquid titanium and additives
    Success Is A Mindset.
    mamehmood's Avatar
    Sep 2008
    702
    Engine oil grade to be used according to the engine life; i mean in new vehicle it is recommended to use 10w40 but not after 20,000 or in old engines.
    Sent from my SM-G920F using PW Forums mobile app
    muhammadasifmehmood@yahoo.com
    Cell#: 0300-4007480
  12. #12
    pakiboy104's Avatar
    Dec 2008
    399
    I am using 10w40 LM and I am changing it on 3000km and still usable for more 1000km according to mechanic it can use more 1000km
    Sent from my SM-N910G using PW Forums mobile app
  13. #13
    mr.zshawn's Avatar
    Jan 2014
    134
    Air cooled engine hein sb. So if u ver using 10-40. Then keep sticking to it. Till it dosent smokes out. Or reduces.
    Don't change ur brand so offten. Every oil has its own protective layer. Which can b dangerous on changing.
    An expert apprised me in a way that one should not change the brand grade b ager change kerney hein tou same brand mei raho... Either wise search for the best match in other brands.
  14. #14
    aks_e_ahmed's Avatar
    Jan 2010
    32
    9,426
    19
    232 Post(s)
    11 Thread(s)
    FOr new bikes LM 10-40
    For Old Bikes More then 20000KM LM 20-50
    I am using LM 20-50 And drain it after 2000KMs
    My bike Gs 150 2012 model and run more then 20K KMs
    I am satisfied with it
    He Who Is Not Courageous Enough To Take Risks Will Accomplish Nothing In Life....!
    Muhammad Ali
  15. #15
    Jan 2010
    32
    9,426
    19
    232 Post(s)
    11 Thread(s)
    Muhammad Ali
  16. #16
    aliarshad26's Avatar
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
    Quote Originally Posted by aks_e_ahmed View Post
    @aks_e_ahmed
    @aks_e_ahmed
    10000 (ten thousands) km driven YBR is taken as new bike or old bike???
  17. #17
    knight.robot's Avatar
    Aug 2016
    56
    ???? where did u get this info??
    i m pretty sure its incorrect.
    do u even know what 10w-40 means? or 20w-50
  18. #18
    hamikhan's Avatar
    Jun 2014
    Other
    1,261
    39 Post(s)
    Use 10W40 because GS engine is OHC (over head cam) that,s why company has recommended A thin oil 10w40 for it
    thin oil lubricate+flows more frequently than a thick
    Always Use synthetic oils because synthetic oils are far far better than minerals
  19. #19
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
    Quote Originally Posted by hamikhan View Post
    @hamikhan kesay hen aap ???
    11000km driven bike mien 10W40 dalna chahiye k ni??
    winters bhi hen abhi
    pehly bhi 2 baar 10w40 use kiya hy lakin baki baar 20W50 he use kiya hy dost ne bike is YBR
  20. #20
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
