Shiny.*-)
Info.
Honda CBR 1000RR Fireblade
An all new CBR1000RR was introduced at the Paris International Motorcycle Show on 28 September, 2007 for the 2008 model year. The CBR1000RR is powered by an all new 999 cc (60.9 cu in) inline-four engine with a redline of 13,000 rpm. It features titanium valves and an enlarged bore with a corresponding reduced stroke. The engine has a completely new cyinder block, head configuration, and crankcase with lighter pistons. A new ECU delivers two separate revised maps sending the fuel and air mixture to be squeezed tight by the 12.3:1 compression ratio. Ram air is fed to an enlarged air box through two revised front scoops located under the headlamps. Honda claims power output to be at least 178 hp (133 kW) beginning at 12,000 rpm.
Honda made a very focused effort to reduce and centralize overall weight. A lighter, narrower die cast frame was formed using a new technique which Honda claims allows for very thin wall construction and only four castings to be welded together. Almost every part of the new bike was reengineered to reduce weight including the sidestand, front brake hoses, brake rotors, battery, and wheels.
In order to improve stability under deceleration, a slipper clutch is now available with a unique center-cam-assist mechanism. The Honda Electronic Steering Damper (HESD) has been revised this year as well. Another significant change is the exhaust system which is no longer a center-up underseat design. The CBR1000RR now features a side slung exhaust in order to increase mass centralization and compactness while mimicking a Moto GP style.
For the 2008 model year, the CBR1000RR competes with the Suzuki GSXR1000, the Yamaha YZF-R1, the Kawasaki Ninja ZX-10R, and the Ducati 1098.
