1989 Nissan 240SX
Owner: Jared Hageman
Hometown: Bowling Green, Virginia
Daily Grind: Manager At Do It Best Homecenter
Under the Hood: 1989 1.8L CA18DET; KA24E throttle-body; Z32 mass air-flow sensor; Drift Factory aluminum pulleys; SARD Sports EX air intake; DSM 450cc fuel injectors; NISMO fuel pressure regulator; Walbro 255lph fuel pump; Z32 TT fuel filter; SARD Torque Control Valve; A'PEX'i N1 titanium gold muffler; Jet-coated OEM exhaust manifold; OEM T25 turbocharger @12lbs; SARD R2D2 blow-off valve; Godspeed intercooler and piping; OEM Koyo radiator; Yashio Factory cooling panel; NISMO radiator cap; Samco Sport hoses; Circuit Sports catch can; SARD Magic Box; Power Enterprise V-belt; Powder-coated valve cover
Power: 220whp/256lb-ft
Drivetrain: Competition stage 2 clutch; Infiniti J30 VLSD; Cusco brass bushings; NISMO shifter, slave cylinder and stainless steel clutch line; Redline gear oil
Brains: E-Mance reprogrammed ECU; HKS turbo timer and EIDS
Stiff Stuff: Fortune Auto 40-way adjustable coilovers; Circuit Sports front strut-tower brace; Energy Suspension bushings; K-Sport rear upper control arms; Battle Version traction bars; SPL toe arms, Peak Performance rear urethane swaybar endlinks; Secchi pillow-ball tension rods; Nagisa Auto fender braces
Stoppers: Z33 front brake calipers; R1 Wurks Z33 aluminum rotor upgrade bracket; EBC Z33 cross-drilled/slotted front brake rotors; Peak Perfomance 5-lug hubs; Agency Power stainless brake lines; Z32 rear 5-lug conversion;
Rollers: 17x9.5 +18 Enkei RPF-1; 235/40-17 Nankang NS1 tires; Project KICS 20mm wheel spacers (front);18x10.5 +15 Enkei RPF-1 (rear); 255/35-18 Hankook Ventus K104; Project KICS 30mm wheel spacers (rear)
Outside: PPG Nissan Imperial Orange w/gold flake; Gloss black roof; Version Select Type 1 widebody kit; JDM Nissan 180SX Type-X taillights, carbon fiber pillar garnish, window visors, rear-quarter glass louvered-visors and quarter glass; Pivot Sleepy-Eye Controller; carbon fiber Wangan-style wing
Inside: JDM S14 front seats; JDM 1996 180SX lighted keyswitch; S14 manual seat belt conversion; Nardi steering wheel; VIP-style cluster trim, aluminum gauge bezel, UKDM 200SX gauge cluster; Ichiban pedal set; Carbon fiber armrest, console overlays, door sills, custom cup holder; NISMO leather shift knob; Yashio factory E-brake knob; Autometer carbon-fiber boost and oil pressure gauges
Ice: Powerbass Evolution 6.5" components, coaxials, midbass drivers; Powerbass Autosound ASA400.4 amplifier; Mobile-Spec wiring; Panasonic CQC9901U head unit; XM Radio
Props: RHDJapan.com, Terry at Fortune Auto, Versus1, John Jansen, A&M Homecenter, Fredericksburg Powdercoating, Southern Truck & Customs
