Any Upgrades
Not till now. However, I plan on doing following 02 things:
- Installing a reasonably priced Android Headunit
- Upgrading Tires and Rims
For Android headunit, I will be highly grateful if someone could suggest a good and reputed shop in Rawalpindi / Islamabad, from where I can get it installed. Price does not matter (although it does, and should be reasonable and not too costly, like 35-50,000 PKR. 15-18,000 PKR should be sufficient), however, product should be genuine, original, with warranty and should work!
With my last ride, I just upgraded tires, standard rim size was 13". Although I did not face ground clearance issue that much in my last ride, but still, I plan on upgrading in my new ride.
I do not suggest for upgrading tires and rims other than stock, OEM recommended ones, however, just as pro-active approach and avoid any sort of spacer springs or packing, etc. or ground clearance issues in the future, I want to upgrade.
For rims, I plan on upgrading from 14" standard steel rims which came with the car, to 15" alloy rims. The standard size of tires is 165/70/R14. I just discussed with a guy, and he suggested me to upgrade from 165/70/R14 to 185/70/R15.
What do you guys suggest? Would it be better? or there is some other, better alternative? Suggestions from experienced would be much appreciated. Recommendation about tires and rims shop(s) will also be highly appreciated.
