Salam friendsMara pass Toyota Corolla Altis 1.6 A/T SR ha .problem ya ha kẵ car ma trekker laga how ha jab be 3 or 4 days ma start nahi kar ta tu battery low ho jate ha ... Ma tu tang ho Gaya ho ab . How I save battery? Help me
If battery really gets drained in 3~4 days than ask your tracker company to check it normaly a car with tracker can easily stands up even after 7 days of rest.
or as an alternate, start the car (ideling) for atleast 10 min after every 36 to 48 hour. It will help bettery charged.Winter is almost here, so better do ideling after 24 to 30 hour as max.
Sent from my GT-P1000 using PW Forums mobile app
Ok dear inshallah tomorrow contact helpline..
dear sirf starts sa be faraq nahi parta few kilometer rune Karen hote ha phir ja kar charge hote ha.
Your battery is bad, check with meter.. Not a trakker problem, had a similar problem with a gli at and the battery was culprit. The car was driven only 2500 km in 1 year. Battery changed everything resolved..
Sent from my Nexus 4 using Tapatalk 2
battery is not holding the charge. In this case a battery (under warranty) can be claimed if found faulty.
check if any wire is touching to body and is leaking current, happened once with a friend a wire was touched with body and all current from battery drained then he had to charged the battery. Go to some good electrician or Toyota 3s.
