Below is ur auction sheet verified
U can do manual search thru lot number...ur sheet is genuine
Thanks a lot dear. Please also advise is this the complete image of the Auction sheet?Shall also appreciate if you could advise what should be the price for this car, appears to be in very good condition.Thanks in advance.
Should be around PKR 1420000 to 1440000 range
@vetocars Now check
Had to spend $10 for them to find it. Now record is available but have to pay $20 to receive the report. Will ask buyer to pay.
@vetocars Thanks...Should I buy it in 14,00,000?
Why the extra cash? Wasn't it only 10USD for receiving it?
They charged usd 10 for 'manual search' since the record was not showing in normal search. When you search via manual search, first you have to become vip for which they charge usd 10, then usd 20 to view sheet once record is found.
Is it possible to do this on an older car imported in 2012/2013 with no record of auction sheet?
can try
its possible, since they have several years of data. But what would be the use of checking a car imported in 2012? Unless you have extra $$$ and want to see the outcome, and potential of this service.
Assalamualaikum,
Need to verify following auction sheet
please confirm me the auction sheet forToyota PassoChasis# KGC30--0224666Model# 2015
Assalam-o-Alaikum
2017-03-31 > USS Osaka > № 4169
wassalaam
@umarmuslim bro will highly appreciate if you verify this car sheet. Regards
Vitz 2014
KSP130-2119117
@ali_akbarVitz Gray 2014 sheet...3pcs replacedwhatsapp at 0345-8220096 for further details
3 parts replaced& 1 sprayed
its front hit
certainly should avoid this car
What a Catch !
reversed to 1/7th of original mileage
Always Verify !!!
Better Safe Than Sorry !
Kindly need auction report,
Prius jun 2010Chasis # ZVW30-1257166
Wsalam.
