Probably, using 9:1 in foam lance at this moment.
Is your Sygic navigation activated. And congrats btw.
Hello. Could you please guide me on which bulbs to get for fogs? The link you gave in Post 595 has socket types H1, H11, H8 etc. Which of these fits the fogs.
https://www.aliexpress.com/item/CNSUNNYLIGHT-H4-Hi-Lo-H7-H11-9005-9006-Led-Car-Headlights-8000lm-3000K-4300K-6000K-High/32822226023.html?spm=a2g0s.9042311.0.0.d4akjD
For the main beam (Lo), can you suggest some LED bulbs like the ones for the fogs? Mine is a pre facelift 1.6 Altis so no projectors.
You also posted about Morimoto LEDs for reverse lights? Do give a link if possible.
Thank you.
@autophileI need some suggestions. I have Corolla Altis 1.6 2016 model. Very less driven 28k, Which engine oil do you suggest 5w30 or 10w something from Toyota and what is exact price. Also i have an issue with screen can you help what can be wrong? Reverse camera when initiated shows perfectly but normal screen is showing strange numbers and i cant do anything when i touch the screen plus sign appears only. need suggestions
You can put 5-30 Toyota tin pack, but you will have to buy two packs as 4.2 litre oil is required. I am using Taglon 5w-50 to maintain warranty.
The number on your screen are for touch calibration.
Touch calibration means? how can i fix it. I cant access main menu etc
just touch the circles in given order and screen will show up
https://www.pakwheels.com/awards/2017
Any comments on this?
I did but there was an error at the end in chinese. and sometimes that error comes other times it starts from 0 even after i complete it.. Any ideas?
Did you try resetting with a pin?
Yes i tried it didn't help
Disconnect -ive battery terminal for few minutes and then reconnect. It's a temporary software glitch.
Ok i will give it a try. thanks
Where in Islamabad are you located? is it possible that we meet up and i get a detailed analysis from you in person?
@autophile, please tell me about this sponge? Was thinking of ordering car clay but remembered that you used some kind of sponge on your grande. From where can I get one and is it washable/reusable?
I bought the one given in the link below. It is reusable and washable if dropped.
http://shop.luxeautospa.biz/shop/nanoskin-autoscrub-sponge-fine-grade/
Thanks! You're a big help
There are two types of sponges available. Medium and Fine grade. Which one should I go for? The vehicle paint is 8 years old and never been clayed before.
Fine grade is for new vehicles, so I guess medium will do.
Yesterday completed 10,000 kms. Alhamdolillah enjoyed every km of drive.
