Corolla 90, 4AFE stalls a little bit when moving from stationary. No stalling in case of moving with a bit heavy foot.Possible reasons?
Might be because of poor fuel delivery, check fuel pump, fuel filter and injectors.
That's the case with both CNG and Gasoline.
my cultus also had same problem,, its clutch plate was weak,,, changed it n problem gone,,so ur clutchplate may be weak,,m not expert, telling on the basis of self experiance
it is a clutch issue.
If it jerks only when you release the clutch b/w gear shifts then possibly its your clutch plate.
leaner AFR Ratio's both on CNG And Petrol get them checked first..
