@ beeberg
the diff in GTti is that it has 4wheel disk brake.front + rear. of course the hand brake system is also diff. so the master cylinder n booster is bigger n more powerful than ordinary charade. fitting is same but the cylinder is shorter in size with bigger dia. same as booster is bigger in dia n shorter in thickness n the result is excellent
btw there r 3 ,4 types of GTti cylinder n boosters. try to find the cylinder n booster with max dia :d
meri apni charade main GTti walay master jee n booster uncle fit hain :d brake ka maza na aaie to paisey wapis
