Hello.
All the car lights have started to flicker all of a sudden. Also the car multimedia restarts when i turn on the lights of the car.
Is it the alternator or something else. How to quickly diagnose
Please do mention some details regarding your car; make, model, model year, etc.
Most common causes can be problems with Alternator, loose or disconnected ground wires or ignition wires, after market equipment, battery, voltage regulator, etc. Check one by one, and take remedial action accordingly.
Following links may help:
https://itstillruns.com/fix-flickering-vehicle-lights-5058944.html
https://www.mazdaoflodi.com/blog/causes-of-car-lights-flickering/
and
https://www.trianglecarcare.com/determine-alternator-battery-needs-replacing/
Thank you.
Car is 2011 civic. Nothing aftermarket installed totally stock. After an hour of parking it. The car is just fine nowm i guess i have to clean them terminals on a sunny day.
Yup check terminals and ground. Most flickering is caused by disturbance caused by improper ground or rusted ground etc.
brother my car does pretty much the same. some time from start the stereo plays the 1st song in usb just as if some one has taken out the usb and pulugged it in also on using dipper couple of time too many times the stereo stucks and i have no option but to take out and insert usb. car is civic 05.once an electrician tightened the ground wire by saying its loose and my car showed immenese pickup but after few days car showed sluggish behviour. i just popped in new battery but havent tested it yet with dippers.....my question is how can i test the ground wire
