Guys my civic 2000 Vti oriel is going all fine but there are few things i don't like , and am not able to make them right so needs ur help
when i put the Headlights On , RPM drops 200-300,
when A/C is on while car is in rest position RPM fluctuate at 100-200 which makes car vibrate and slow pick and the compressor do like clutch clutch means rapid on and off on off on off on off,
and i have to switch off the A/c when at idle,
when radiator fan gets On again RPM drops,
and my car is giving 80km in full CNG cylinder with 50% a/c on , how to make it better , i have heard that this car should give 120kms with 100% A/C on in city.
and i saw my friends city 2000 , A/C on headlights on with HIDs there is just a lil drop in rpm like 100-150 and car is very stable.
I've done tepid adjustment , throttle body , timing belt inspection , CNG kit and cylinder oil drain , spark plugs inspection ..... gas tuning .........
so is there any electrical issue , voltage is not proper??? , what is ur recommendations to make it better ...
thanks in advance:)
