Thank you Brother, will be visiting him & see what comes out of it.
From where did you get the tensioner worth 2500? Or was it just the bearing? If it was the bearing where did yiu get the genuine bearing from?
Not the full tensioner only bearing and belt nasir motors plaza karachi they said its oem china bought many stuff before no complaints till yet they only deal in honda parts
Does your car make gur gurr noise at 1.5k rpm?
Yup but on its time not continuously
Guys be sure to put in 3.5 litres of Oil in Turbo at oil change and not 3.7, extra oil causes pressure which is the reason behind Engine oil seal leak, I told them to consult their manual after they did they said I was right and poured 3.5 another car also was poured with 3.5.
Hi brothersI have a oriel delivery this Wednesday in Karachi from honda defenceIt's oriel with leather seats and navIt's my first time civicKindly if someone can guide what to check while accepting car from dealership?Any specific or particular? Help needed
Overall cost? Parts and labour? From which workshop in khi?
Just check the doors in general there allignment specially the silver lining over windows opening closing and scratches paint marks. Otherwise it will be ok inshaAllah
Thanks a lotShould check any specific regarding removable items like cameras nav etc does dealership do any hanky panky by locally replacing them
Take delivery in morning
Spend 01 hour with car
General finish and alignment
Functioning of lights , navigation etc.
Don't worry, it will be ok
Is it possible in LAHORE to swap your OEM Rims and Headlights for FL Rims and headlights without costing an arm or leg? Please guide if possible
Thanks a lot brother
Any idea about uc6 tyre prices and what I should get with my ex factory tyres
Which engine oil brand is best for civic x 1.8. I have to get engine oil changed. Its 8k driven 2018 model. Please tell which is better between amsoil and liqui moly? Note: I will also be using liqui moly ceratec in next oil change
If one of your options is LiquiMoly, then u don't need any comparisons.I mean, there would be oils better than LiquiMoly, but LiquiMoly's own quality is so top notch that u don't need to worry about any other oil.
Just meet ETO PA, he will send you to computer section to see if number is available. If available they will mark it on file and tell you when it will be available. No سفارش, agent needed for this. This number has no fee.
Ex factory tyres fetch you 20k
UC 6 costs around 76k
Thanks brother
AoA guys.Oriel 2018, 30k odo.I noticed since yesterday that the auto door lock when car touches 15km is faulty. As it locks and then after regular intervals mild locking sort of nose comes once and then repeats. Another thing I noted is that when I lock the car, the front and rear indicator lights don't turn on. Just the locking sound comes, no blinking yellowish lights.Any remedy/suggestions please.Want to get it fixed as Ramadan is about to start and then routine becomes tight.
