HHow to restart turbo's navi screen? It hangs and the screen black out. Doesn't even turn on after the engine is restarted. Only the back cam works when in Reverse.
My navigation system of civic gets stuck and the screen stops working when i start the car after a day or after few hours. Then I have to restart the car 4-5 times just to get it start working. How to fix this issue?
Swipe down and get to top menu
On right most , close all
It will reboot system
Can someone suggest led headlamps for low & fogs. (No maximus bs) pref local purchase or aliexpress?Fogs are H11? What about lows?
Low are also H11
Any one with the info how much KMs before the turbo charger needs servicing? As i am about to hit 50k mark just curios how much dirty it would be.
Weird. Honda I8 specifically told me to avoid V Power.
Dear Friends.Meguiars polish, m21 sealant n wax applied a month ago.carnauba wax done twice a month.can i use ultimate polish once in a month if it doesnot destroy the sealant to enhance shine or not?
If you are in lahore simply go to tracking world faisal town lahore and change the headunit in warranty free of cost.. same was my problem.. i got new with in 10 Mins
Steering wheel stitching in progress. Central console done. Doors armrest couldnt install @Khurramchauhdary help needed. Brakes padle covers replaced
I am using Photum premium LED bulbs in my Civic. Lights beat my HID retrofit setup on my Honda City. There's a page on Facebook by the name of BI LED . Check that out.Low beam= H11Fogs= H11High= 9005
What Projectors did you use for your retrofit??
Guys,Has anyone changed cvt fluid yet? Manual says 40000 or 2 years. My car has less than half the mileage but almost 2 years old now. What is the recommendation here, mileage or duration? And what is cost if anyone has an idea?
Here's my thread. You can check it out yourself
Oh, I've seen your car before. Ibad Bhai sent me its picture.
I would say follow till 40k
What is solution to wifi issue? I tried it on it but it stays off.
See video through this linkhttps://photos.app.goo.gl/6BxryqqAAXTQC1hR6
Fuel ??
As it says 40000km or 2 years...... The time span is mentioned due to some reason..... if its 2 years comes before 40k then simply change it...... Sludgy contaminated acidic Oil will ruin your Transmission if prolonged further.
Reset with pin. Scroll up follow my post. I faced same
