Guys, in my city 2009, when i press clutch, it stays there until i pull it forword. what can be the issue.
Something wrong with hydraulic system of clutch
Maybe you have a leak. Check the clutch master and slave for leakage. Did you do something recently that caused it? Could also just be air in the system.
Master Cylinder for the Clutch is leaking brother!
thanks guys, nope didn't get any work done. what will the solution for leaking master cylinder.
Change the Seals in the master cylinder
