TROUBLE SHOOTER!
a)less air required for efi and engine more than 1300 cc.
b)first adjust rpm on petrol frm carburator and then convert it on cng and then adjust it frm kit but beware,it can effect starting time.
c)it is in kit regulator behind high pressure plate,but i dun think tht is choked,.to check it,see if the pressure of gas from guage decreases when u accelerate ur car,if yes it is choked,if not,it is ok.
d)problem with ur tappet adjustment,redone them according to weather condition...
i think i ha answered for ur all questions if not,u can ask me
thnx
KASHIF!
if ur mechanic is not greedy, then tunning will improve ur car...well,for u ,i can do it!
take a screw rench or 13 mm GOTI or CHABI,open hood and look at the kit,exact its below,there wud be a bolt tightened,open it(only it 13 mm) and if there wud be some oil,it will drain , if not theres no oil.
u hav landi renzo kit installed na :o ? it is for landi renzo .
