Very strange that you are facing frequent failures of an aluminum radiator. i have a few questions:
1 - Is the radiator you fitted locally made?
2 - Is it a brand new one or used one from a kabariya?
3 - Are you using coolant or plain water?
4 - Are you sure you don't have a head gasket leaking combustion gasses into the cooling system that is over pressurizing it?
Copper radiator will be next to impossible to find, You will have to get one made to order. I don't think there are many old school artisans left alive who even have the skill. The one I knew in the street next to Benazir Hospital passed away a few years ago. If you are able to get a copper radiator, you will have to be mindful of the coolant you select. Coolants that are safe with aluminum tend to eat the solder used to put together the copper radiator. What you need with copper radiator is Inorganic Additive Technology coolant.
