Salam to all.
My KE-70 is facing vibrations problem on high speeds. I think it is due to drive shafts U- joints, i got them changed but still the problem sustain..What to do ?
Sent from my Desire HD using PW Forums mobile app
inspect the U joints that they are pressed in correctly and greased up with sticky wheel bearing grease _the U joint can fling off grease due to centrifugal force.
The other bit that causes vibration is a worn or dried slip yoke or a bent driveshaft.
Today i went to my mechanic. I checked U joints, they were fine and correctly pressed. Filled them with grease with a proper grease filling gun. Went for a try, vibration is still their.
wheel balancing karao!
how old & worn out are the tires of your vehicle
check list1:check ur tyres they are in good conditoin and shape2:check ur rims same as tyres.3:wheel alignment and balancing.
Tyres are in good conditions and rims are also fine. My steering wheel is also steady on high speeds. But today i also experienced one more thing i.e. when i acclerate upto 80 km and then left the car on neutral VIBRATION hi VIBRATION..
urrm... engine mounts?
Engine foundation or Axcles is slightly bended
Ok..i will check out the mounts
