Today I went for brake tuning & radiator water change,mechanic inspected wheels & said 1st get service wash done with diesel spray under engine, maybe noises coming from brake will disappear,if still not then he will do brakes service.Radiator water was changed too,drained water still had green color of coolant that was put in my old radiator,after filling water still there are rust particles visible in water that comes up to neck of radiator.Maybe next time on draining water I should tell them to drain water with pressure by air.
I then told mechanic that I am suspecting increased fuel consumption after changing carb,distributor, he removed plugs & 1st of them had black oil deposits on it while other two are reddish color,he said all should have reddish color on tips.He recommended me engine overhaul,gave estimate of 30-35K including all rings,pistons,valves work but says no guarantee of any kind will be provided.For time being he told me to keep runing car as it is & said current mixture settings are best according to him.Give your suggestion guys.Currently I have no plans for overhaul or engine swap as it isn't causing me problems,i mostly drive in city & don't notice big oil reduction.For last 3000 km car has run,it was mostly within city with 1 tour of islamabad & another 80km trip & about a half litre or less engine oil was added.Please share your views if in future I make my mind or car cause problems then should I go for overhaul in 35k or swap.
