Cuore2006 is mising on cng and if i put ac on its do mising more i went to my regular mechanic he did tunning 2 times in last few days, change plugs, point etc but all in vain. Plz tell where should i go now , i live in dha area lahore.Regards
I suggest you to go toyota showroom, they will charge you 800/- but beleive me they are best in cng settings of cuore because cuore is toyota baby.
bro go to any good cng pro they will solve your prob
change the ignition coil or desi totka bypass resistance will will solve ur problem
Problem is sloved by toyota airport motors. Distributor cap replaced, Oil in 1 plug due to timing out, Plugs replaced and timing adjusted. Engine is getting weak as it crossed 2 lac kms.
