I have Mira 2010 Model Having Chasis no: L275s.
My Mira is 2wd.
Mira 2wd ABS unit Number is DL101 89540-B2190.
I have 4wd ABS unit Number is DL102 89540-B2200.
Both ABS unit are 100% identical.
Now the problem i am facing is that my speedometer is not working.
Mechanics told me that you have to replace the ABS unit otherwise there is no way to run your speedometer.
ABS unit are hit few days ago motor cycle thats why speedo meter is not working.
Now i have 4wd ABS unit looks 100% same as 2wd ABS unit.
Is 4wd model ABS unit will compatible or works with 2wd model ?
Please suggest.
Actually i dont want to change my ABS unit because its very expansive....People in Bilal Ganj Demanding 25k to 28k.
Is there any way so i can run my speedometer?
Need suggestion from experts.
