when using a synthetic oil, its economically not feasible to change the oil at 5000 kms, infact your engine is not even specced for it, its very easy on its engine oil. So unless you have money to burn dont change the oil out so prematurely. Which then opens up another problem avenue, small sump engines with small general paper filters are not very reliable on such oils because the oil itself maybe good chemically (as in the add pack has just burned off the detergents in it - and actually started to use the added minerals which help the engine) but the oil itself may become abrasive as the filter media is not efficient and the entire oil hold is pretty low volume.
And whats the hassle in changing the filter, it takes 2 minutes to undo and install a fresh one and top up with some generic mineral engine oil - a little mixing up doesnt matter.
