Check if its radiator fan direct, if it is then check if thermostat valve present.
Drive around 3 to 5 km with AC on in rush area see if you listen any weird sound
How much car is driven ask the owner and get an electrician along with u he can tell u if speedometer is tempered or not, also make sure if computer chip is working alright.
Take mechanic along with u and get an estimate that how much further work required after buying this car
Check car owner book, make sure it shouldn't be duplicate copy
Check car body if there is rust on its floor or anywhere..
Do u have photos of the car? If it is recently overhauled then compression test value should be around 12 for all cylinder s
Sent from my SM-T211 using PW Forums mobile app
