Honda 0w-20sn.
Not sure about knocking but dipstick vibration is normal. Need to see if knocking sound is coming from outside or inside
+1True that and use 5w 30 by total. That's better option and you may use Mos2 by liqui moly
Not only engine, it is body to power ratio which effects the fuel economy. 1.3 and 1.5 have same body and fuel average is almost the same in my opinion. However it can vary with driving style and environmental conditions.
Is it for fist oil change, but Honda recommend to change oil filter at 10k km and what is this Element Assy, Air/C ?
Element assy is air filter.
Air filter area is moving. Sound is normal but this movement of air filter box is not normal. Maybe some bolt is loose.
ill check it out. thanks.
Spot on. One of the two bolts that holds the air intake area was a bit loose. Less vibration now.
Do they change Air Cleaner at first oil change, as per owner's manual it should be changed at 25k kms and also oil filter at 10k kms.
Air cleaner changes at 10,000km..depands upon environment conditions if it more dusty change it early.
I need the user manual for 2007 city i-dsi.
Thanks.
Hi have you found the answer, as i am also facing a similar issue when driving on highways
Nope not yet. Still searching
Hi,Anyone can suggest some place in Rawalpindi/Islamabad from where we can get some good quality Alloy rims for Honda City 2018.
anyone else with mid June booking for aspire pt? Iām kinda getting impatient now. Worst part is atlas Honda never answers their phone.
Been trying these 2 numbers and they never answer. 0301 8423 9840301 8423 982
Havent noticed RPM at 1201.5 is doing greatPick is awesomeFeels very light when pushing the pedalMileage. I am not getting very good yet. The cluster shows around 11. I hope it will improve over time
Yes i got it on my City 2018, it cost me Rs. 22000 from NShield Islamabad, it really works and i am satisfied with their work and it depends how maintain your car. I got my car coated 6 months ago, so far it good
