it is useless cleaning airfilter and do not using engine oil or gear oil
oil is the real item which work as an filter and stops dirt from going inside
Oil should be spread evenly all over filter foam
honda mechanic in my city use to clean filter with patrol only
but some days back i was there and found him he is now also using engine oil
as AHl has strongly suggest them to use oil for filter cleaning process
Racer bhai it is not recommended to pour oil directly on air filter
as oil does not spread well it sticks to only some part of filter
and bro you should watch some tutorial video on youtube or the one which i had posted
while squeezing one should be careful you can damage foam. Try to squeeze the foam as
the guy does in video tutorial it will be more easier but squeezing does require some hard work
so you need to waste some energy to properly squeeze out all oil from filter
Sorry brother please don't mind but i thought i should point out those two mistakes
i use to do same but as you do again & again and by time you learn & get experience
brother i am not an expert but as an friend i pointed out those two things of yours squeezing & pouring oil
Brother i saw a video on youtube of Yamaha inshAllah will share its link
it will further help you understand this process more i learnt proper way of squeezing from that video
youtube does not work in my desktop inshAllah will share link after searching video on youtube on my brothers laptop
bro i apply now same method to squeeze out oil from filter while cleaning generator & pridor foam filter
I still believe i don't this whole process perfectly and i am not an expert and still try to further improve
and bro buy an special pot for this process do not use any kitchen pot
or even if you use do not use that pot again for kitchen purpose
i would recommend buy small plastic tub or pot which you have seen in my pics
